April 18, 2024, 04:23:51 AM *
Author Topic: Lock and lock pin worn down  (Read 1848 times)
S2R 800 '07
« on: August 09, 2021, 08:53:41 AM »
I'm pretty sure I'm one of the few, if not the only to experience this - strange issues keep appearing on my 211,000km bike. Yesterday I couldn't lock the seat.
Closer inspection show badly worn locking plate/hook and pin.
New/used locking mechanism might be available.
The pin is another story....  I thought about welding a lump on it and then grind it back to normal, but the seat pan plastic is quite close. Too close?
Thoughts?
« Reply #1 on: August 09, 2021, 09:04:08 AM »
Have you tried unscrewing the pin? If the seat pan is plastic it had to be installed and not part of the seat pan.
S2R 800 '07
« Reply #2 on: August 09, 2021, 09:11:12 AM »
Can't see any screws.....  I thought the pin is embedded in the plastic....  Maybe accessable from the cushion side....
« Reply #3 on: August 09, 2021, 09:50:52 AM »
Could be...
« Reply #4 on: August 09, 2021, 11:15:00 AM »
Lock is available separately. Pin doesn't seem to be.
I'd weld it with a mig welder. Just don't run a bead. Small stitches will build it up enough, and shouldn't get it hot enough to loosen it from the plastic. If it starts getting warm, let it cool. The grind it, slowly, to the proper shape.
S2R 800 '07
« Reply #5 on: August 09, 2021, 11:39:34 AM »
"Grind it"....  will a Dremel do?
« Reply #6 on: August 09, 2021, 12:55:29 PM »
Sure.
You could also try a steel epoxy putty...like this...
https://www.amazon.com/J-B-Weld-8267-SteelStik-Reinforced/dp/B00RN7CT2U
booger
« Reply #7 on: August 10, 2021, 07:04:51 AM »
try clamping a locking pliers to the bottom of the pin before you weld to serve as a heatsink, my concern is as soon as you hit it with weld it's going to get super hot and loosen in the plastic. And 131k or so miles is incredible
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Heath
« Reply #8 on: August 10, 2021, 12:47:39 PM »
Truly only a "stopintime" problem lol
2007 Ducati Monster S4RT
« Reply #9 on: August 10, 2021, 02:10:31 PM »
With a fair amount of experience with welding, the proper procedure won't get the pin very hot.
