April 23, 2024, 10:55:34 PM
Length from Stem / Lower Triple to Axle?
Topic: Length from Stem / Lower Triple to Axle? (Read 1261 times)
ajw85
August 10, 2020, 12:01:55 PM »
A long time ago I did a front end swap and I don't think I set the distance from the bottom of the stem / lower triple to the axle properly to maintain original monster turning characteristics (rake/trail). Can someone pretty please measure this so I can compare / reset it to original monster values? My monster has been a bit twitchy since the swap and I'd like to get it back to it's original steering characteristics.
Re: Length from Stem / Lower Triple to Axle?
August 10, 2020, 01:46:16 PM »
Which Monster are we looking to set up?
S2R 800 '07
August 10, 2020, 01:53:50 PM »
The swap surely changed the sag numbers? That's much more important than a few mm of mounting difference.
In my hunt for a suitable geometry, the relation between front and rear has been high on my list - beaten maybe only by front/rear suspension harmony.
ajw85
August 14, 2020, 12:17:46 PM »
Quote from: Speeddog on August 10, 2020, 01:46:16 PM
It's a Monster 800.
I never set sag as part of the swap (I know).
Online
August 14, 2020, 02:43:21 PM »
I'd like to see how far the fork tops are pushed through the triples. A "bit twitchy" may mean needing 10mm more front ride height as a starting point. Setting sag first as mentioned is important.
August 14, 2020, 07:13:12 PM »
'06 S2R800 spec from the shop manual is 199mm of fork leg out the top of the lower triple
=> Stalla's Pop
