April 26, 2024, 03:13:09 AM
Wire Question
Topic: Wire Question (Read 2905 times)
Norcoastal
Re: Wire Question
Reply #15 on:
June 04, 2020, 03:25:43 PM »
Quote from: Duck-Stew on June 04, 2020, 12:33:59 PM
Agreed, but check things thoroughly before making final connections. I’m not going to come over and fix the bike, or be held liable. Let me know if I can help further.
No worries, no liability, this is all on me.
Norcoastal
Re: Wire Question
Reply #16 on:
June 04, 2020, 03:28:31 PM »
Quote from: dbran1949 on June 04, 2020, 01:46:14 PM
just a quick note to say I don't recognize any of the wiring, but if you are reading +12 VDC on that large black wire with the ring-tongue terminal do NOT connect to ground
I’ll check it again before I make a connection. I’m also getting the Haynes Manual any day now and I’m sure that will help.
Norcoastal
Re: Wire Question
Reply #17 on:
June 04, 2020, 03:34:00 PM »
I know this isn’t very helpful, but the two wires in question are in yellow.
According to the vague reference, the plug goes to the solenoid. The other is the one in question.
Does this help any, or just compound the question?
cheapest gas station around me
Re: Wire Question
Reply #18 on:
June 04, 2020, 04:07:24 PM »
I'm pretty damn sure the ground I showed in my picture is the *entire ground* for the whole bike, except for the starter motor.
If the positive wire is connected to the battery, and that ground wire is floating in thin air, it'll show 12v on it.
Norcoastal
Re: Wire Question
Reply #19 on:
June 04, 2020, 04:10:35 PM »
Quote from: Speeddog on June 04, 2020, 04:07:24 PM
I really appreciate your advice. Thank you.
Norcoastal
Re: Wire Question
Reply #20 on:
June 05, 2020, 08:20:10 AM »
Hey Speeddog quick question,
That picture that you show of your “entire ground”, neither of the two wires that come off of the solenoid are that ground you show connected to your negative battery cable correct?
Can’t see what they are. I assume one goes to the starter and the other to the positive. Just double checking.
Thanks again!!!
Re: Wire Question
Reply #21 on:
June 05, 2020, 11:24:13 AM »
Quote from: Norcoastal on June 05, 2020, 08:20:10 AM
Thanks again!!!
Correct, the two large wires shown in my pic attached to the solenoid, one connects to the positive battery terminal and the other to the starter.
Your harness has a large wire going from the starter solenoid to the connector on the end of the large wire that attaches to the positive battery terminal.
Your post of the parts diagram has correctly ID'd the wires with the yellow highliter.
Norcoastal
Re: Wire Question
Reply #22 on:
June 05, 2020, 02:49:03 PM »
Thanks Speeddog
I put the power probe on it and it’s 100% a ground.
I connected one end to a ground and the other to the lead in question and there is zero current.
Also the power probe detects a ground with a green light and hot with a red light.
Thank you all for your help, MUCH APPRECIATED!!!
Now I have to remove the air box again and the ignition to get to the solenoid to connect the two prong plug.
One last question, is that two prong plug the mechanism that starts the starter? Meaning is that plug connected to the start button? That would make sense.
Last Edit: June 05, 2020, 02:53:46 PM by Norcoastal
Online
Re: Wire Question
Reply #23 on:
June 05, 2020, 03:09:27 PM »
Quote from: Norcoastal on June 05, 2020, 02:49:03 PM
Thanks Speeddog
Yes.
