You will likely find issues with rotor offset, check that before spending money.
This all worked out wonderfully!
...really?; don't fool yourself; and the speed dog is very knowledgeable; lift the front, so the wheels off the ground, spin it; should spin freely; if not fork caliper offset mount is different; and you'd be causing undue stress on the rotors, apply ft breaks while yer at it; do you hear the caliper floats buzzing? … is I think what the dude is sayin
