April 19, 2024, 12:45:04 PM
Front paddock stands
Topic: Front paddock stands (Read 3588 times)
Re: Front paddock stands
Reply #15 on:
April 11, 2020, 01:50:04 PM »
IME anything less than 3/4" pin will bend on an under-triple stand
Online
Reply #16 on:
April 11, 2020, 01:52:53 PM »
Quote from: Speeddog on April 11, 2020, 01:50:04 PM
You may very well be correct, but T-rex sells a 12 mm pin.
Pinion
Reply #17 on:
April 11, 2020, 03:02:03 PM »
12mm is close to 1/2”
8mm is less then 3/8”
It will not be strong by any means,
Not sure how much the pin is used for,lift as is stability
Will trade toilet paper for parts
Reply #18 on:
April 11, 2020, 05:13:08 PM »
I made a pin from a 12mm or 1/2" bolt, cant remember which.
It bent.
Not a 12.9 or grade 8 bolt, but not crapola.
Online
Reply #19 on:
April 11, 2020, 05:16:16 PM »
OK...so why not bore out the stem?
Pinion
Reply #20 on:
April 12, 2020, 02:17:48 AM »
That, I think I would very away from. Things are made a way for a reason.
Hmmmmm......... paddock stand I want vs life, that is a hard one
Online
Reply #21 on:
April 12, 2020, 02:29:18 AM »
Quote from: Pinion on April 12, 2020, 02:17:48 AM
That's pretty dramatic.
The Ducati stem has a big honking hole, and it's perfectly safe.
Some things are the way they are for no good reason at all.
Online
Reply #22 on:
April 12, 2020, 02:43:55 AM »
Is the fancy stem thick alloy Vs a hollow steel tube?
rdtompk
Reply #23 on:
April 12, 2020, 03:03:16 AM »
Get a pin turned out of cold rolled steel and post photos of results!
I had to do the same thing for my previous S2R (don't have a new triple tree stand yet). Worked out well! Granted, I was going bigger instead of smaller....drew it up in Fusion 360 and had a friend of my father in law fab it.
Pinion
Reply #24 on:
April 12, 2020, 03:33:02 AM »
I was actually thinking titanium
I think anything that’s not cast might work
Online
Reply #25 on:
April 12, 2020, 03:47:14 AM »
Keep in mind the stress on the pin is on the way up and down. Speeddog's 12mm. bent and 8mm. is a lot smaller.
Pinion
Reply #26 on:
April 12, 2020, 03:56:14 AM »
Quote from: howie on April 12, 2020, 03:47:14 AM
Yes
Also consider cast is much weaker then rolled, titanium has higher stress values
Honestly if you consider using a valve, nipping it off and drill out a receiver
I have used a valve out of a 350 to adjust coil over compression on off road truck on the trail
Last Edit: April 12, 2020, 03:59:34 AM by Pinion
rdtompk
Reply #27 on:
April 14, 2020, 02:26:17 AM »
I think we need to send this to This Old Tony and see a pin made.
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
Reply #28 on:
April 18, 2020, 01:43:26 PM »
Here's my 2 cents since I use the last front lift in your original post; the pin question aside, I've used the lower section with a 1/2" dia. x 2' piece of solid mild steel rod through the front wheel spindle and same way on the rear SSS also for more stability; is doesn't allow for wheel work like that; but is more stable than the pin.
With the pin its less stable, and note; the stand can rotate if you not watching it all the time; as it did on me once, while I was working on the front breaks; I caught it as she went over on top of me; but had momentum and weight as it went down gently on top of me got a little pinned and squished and wrenched my back trying to stop it. I believe they recommend using a back stand to help stabilize and I have used the same rod with jack stands on the rear and front triple pinned. Also its nice that with the pin you can remove the front wheel.
.... all the world is yours.
caperix
Reply #29 on:
April 25, 2020, 10:33:55 AM »
I think the under triple stands for the bikes with adjustable steering stems hooks the lower triple.
https://www.pit-bull.com/motorcycle-stands/front-stands/hybrid-ducati-headlift-front-stand-f0100-500
=> Stalla's Pop
