April 26, 2024, 01:46:54 AM
Front paddock stands
Topic: Front paddock stands (Read 3625 times)
Pinion
April 11, 2020, 04:30:56 AM »
Hope this is right section
Right off,
I have one similar to the first pic, fork cradle type, hate it, it scratches the bike, never feels solid, in the way at times.
2001 monster
Options;
pin under fork
Rubber cradle under fork, (me likey)
Pin in tree
Opinions
Type I have, and hate
765A64DA-415F-4341-8815-9826D675D341
by
D charles
, on Flickr
Type I like
C54AC3A0-0FD2-42D1-A655-CF5B64DF7826
by
D charles
, on Flickr
Other type I like
FBB518C0-5B71-4930-B08A-2EEE3921785E
by
D charles
, on Flickr
Other type, not sure it’s an option
6CED504B-8CAF-42B1-A2D1-4DCB3F6F802A
by
D charles
, on Flickr
Will trade toilet paper for parts
Re: Front paddock stands
April 11, 2020, 06:08:20 AM »
Pin into lower triple style, like the last one.
I got one from Lockhart-Phillips.
greenmonster
April 11, 2020, 07:00:39 AM »
+1 on last one.
M900 -97
MTS 1100s -07
April 11, 2020, 07:24:46 AM »
Pin in triple you can do fork work Also, IMO, more stable.
April 11, 2020, 07:36:55 AM »
The under the fork end style make me very nervous.
Even on a lift where there's a wheel clamp holding the rear.
Too many degrees of freedom, and falling off a stand is a calamity
If you have a *secure* way of holding the rear
Two jackstands and a piece of pipe and a scrap of hose
Raise front with dodgy under-fork stands
Pipe under H cylinder with hose as a pad, supported each side on a jackstand
Remove dodgy under-fork stands
Commence fork work
Pinion
April 11, 2020, 08:25:15 AM »
Awesome
Thanks guys, do any that you know of have a 7mm pin. Aftermarket trees
Last Edit: April 11, 2020, 08:28:36 AM by Pinion
d3vi@nt
April 11, 2020, 09:13:34 AM »
You might check T-Rex:
https://www.t-rex-racing.com/Triple-Tree-Stands-s/439.htm
You can buy individual pins and swap them out for whichever bike. Not sure how their measurements work, though.
'13 MTS GT
'99 ST2
'07 M695 - Sold
April 11, 2020, 09:25:57 AM »
7mm pin?
Got a picture of the bottom of your stem?
Pinion
April 11, 2020, 09:39:27 AM »
13mm is the smallest pin i can find
C79C751A-0070-4CDF-9753-A5B9C4A33032
by
D charles
, on Flickr
Last Edit: April 11, 2020, 09:47:12 AM by Pinion
April 11, 2020, 10:13:39 AM »
I don't remember the size pins on the Pit Bull I had, but way bigger than 7mm. What lower triple is that?
Pinion
April 11, 2020, 10:36:56 AM »
AEM
It’s an 8mm hole
Might just go with the one with pins in the bottom of the forks
April 11, 2020, 10:43:30 AM »
Yeah, you gotta go fork bottom style
Pinion
April 11, 2020, 10:49:33 AM »
I’m gonna confirm the lightech span, I like it because it’s fixed with pins in the bottom
I can just use my bursig if I need to deal with fork work
Last Edit: April 11, 2020, 11:11:49 AM by Pinion
April 11, 2020, 11:00:53 AM »
Why not have a pin custom turned?
Pinion
Reply #14 on:
April 11, 2020, 11:06:45 AM »
Quote from: ducpainter on April 11, 2020, 11:00:53 AM
Was thinking of that too
Like the idea of the tree stand
Not a fan of the bursig is stand either. Always in the way
Last Edit: April 11, 2020, 11:12:03 AM by Pinion
