Rear Brake Pressure Sensor
Started by Son of a Sith, August 17, 2019, 02:14:07 PM
Son of a Sith
I was installing new rearsets, and the rear brake pressure sensor broke. I am thinking this is only for the brake light (I do not have ABS) is this correct? and I was planning on riding the bike until a new one came in, but I wanted to ask and make sure I was in the right mindset. The bike is safe and I will loose no performance other than a brake light when braking with my rear brake (which doesn't bother me, when I stop in traffic I use the front).
Thanks for your input!
Ride safe!
Do you mean the brake light switch?
A photo of the item you're referencing would help.
OK...it appears Ducati has gone to a hydraulic pressure switch, as opposed to a mechanical unit.
You should be fine.
It's mechanical and it only affects the brake light.
You can ride without  [thumbsup]
Son of a Sith
Thanks! I was thinking so, but this is the first time I've torn into it and wanted to be sure. Never can be too careful.
Thanks again!
Quote from: stopintime on August 17, 2019, 03:23:21 PM
Leave it to the Italians to butcher language. :P
It's a very crude pressure sensor.  ;D
