March 28, 2024, 03:22:37 PM *
Pages: 1 [2]   Go Down
Author Topic: Idle issues  (Read 2282 times)
duckduckgo
« Reply #15 on: June 10, 2019, 09:13:22 AM »
Well I went ahead and replaced the MAP sensor and *poof* problem solved. Maybe just a huge coincidence that it failed at the same time the ECU flash was done? Who knows. Thanks for your help, everyone
« Reply #16 on: June 10, 2019, 09:36:58 AM »
Well, there you go.
By the way, I see you've edited the original post....
duckduckgo
« Reply #17 on: June 11, 2019, 07:55:29 AM »
Well, there you go.
Thankful that it was something relatively simple.
I did edit it - is that a problem?  Huh?
« Reply #18 on: June 11, 2019, 08:37:33 AM »
Depends what you edited.
It *can* make the answers to your question seem nonsensical.
Which makes the thread less valuable to the next person with the issue.
It also can discourage folks from answering:
      "That bloke said he had a flat tire, why's everyone banging on with "Check your TPS"? They seem a bunch of idiots!"
Pages: 1 [2]   Go Up
