April 25, 2024, 12:54:29 PM *
Author Topic: 696 Monster carb sync, only 1 adjuster??  (Read 776 times)
metroplex
« on: May 27, 2019, 01:20:27 PM »
I have a 2009 696 where only 1 of the carbs has an air adjuster screw that turns. The other is either stuck welded or loctited. I am the original owner and the bike is in great shape. Any ideas? Do I sync the carbs with only 1 adjuster screw?
These aren't the droids you're looking for
Enjoying the ride
« Reply #1 on: May 27, 2019, 06:00:37 PM »
WD40 to the screw . . . let it sit, repeat, rinse repat... get the idea? try turn in it to either CWcor CCW to see if it's loosening . . . Do not turn more than 1/4 of a turn at a time
metroplex
« Reply #2 on: May 28, 2019, 06:06:41 AM »
OK, I will give it a try. I'm assuming I need to adjust for idle speed first on both sides and then balance?
