April 26, 2024, 11:01:12 AM *
Author Topic: Cylinder Head (timing system) rotation very tight  (Read 1682 times)
White796
« on: March 31, 2019, 10:40:46 PM »
Hi all beloved Monsterian,
I just opened my M796 engine because of sudden break down (at 110mph) during my last ride.
I found that both of the cylinder head (timing system) very tight. Vertical head is the most tight
My bike is 55,000 km
i maintain my bike regularly at the Ducati dealership
but, when i send there for checking, they also dont know what is when wrong (new workers)
that why i decided to open myself
My question is
1. What is most cause ? camshaft or valve or something else
coz now i'm calculating whether to buy  used cylinder head (complete set) or just change part that broken
and i dont have special tools to open and examine inside the cylinder head and pain in the ass if i used normal tools  bang head
ebay selling about USD300 including post to my country (used cylinder head) x 2
if i replace broken part, maybe cheaper  Grin
thanks in advance..
Hope you all can give me some ideas ..
« Reply #1 on: April 01, 2019, 02:36:03 AM »
You mean that the cams are binding due to insufficient valve clearance when you check the cam pulleys? Or the cam pulleys are binding because the valves are bent?
greenmonster
« Reply #2 on: April 01, 2019, 04:13:05 AM »
Quote
. sudden break down
What happpend, belt failure or what?
Quote
. open myself
What have you opened?
M900 -97
MTS 1100s  -07
White796
« Reply #3 on: April 01, 2019, 10:23:30 PM »
the cam can be rotate but too tight.. and i dont know which component is affected
White796
« Reply #4 on: April 01, 2019, 10:28:18 PM »
belts are ok.. one valve was bent and corrected by dealer.
but the cam very tight to rotate...
that why i asked who got experience with this kind of problems, what is the most likely the problems.
« Reply #5 on: April 02, 2019, 04:29:21 AM »
Have you been back to the dealer?
greenmonster
« Reply #6 on: April 02, 2019, 06:52:24 AM »
Bent valve, replaced, cam hard to turn-sounds like incorrect closing shim. Or belt not in position.
"New workers" didn`t check shims/belt properly, just replaced valve?
If so, they should check/replace shims/belts without any charge. Do have them check both shims.
Any idea why the valve bent?
If piston clearance, shims and belts are proper this should`t happen. If wrong, it could happen again.
« Last Edit: April 02, 2019, 07:03:04 AM by greenmonster » Logged
M900 -97
MTS 1100s  -07
White796
« Reply #7 on: April 06, 2019, 02:48:13 AM »
I also don't have any idea why the valve bent. Dealer only told me but no picture showed - during the inspection.
They 'corrected' the bent, not replaced. (make me confused for a while)
The belt seem ok.
I'll check the closing shims. I think i wont send to them for correction coz i think they still new and dont know what's wrong  laughingdp
greenmonster
« Reply #8 on: April 06, 2019, 04:21:32 AM »
"Corrected"?
On the invoice, any new parts? Damaged valve guide?
M900 -97
MTS 1100s  -07
« Reply #9 on: April 06, 2019, 11:45:35 AM »
If "corrected" means straightened, then that valve should be replaced, and possibly the guide also replaced by a cylinder head specialist. Interesting to see how free the cam spins with the valve removed.
Do you know another shop who can give a second opinion?
« Reply #10 on: April 06, 2019, 06:38:15 PM »
If you cannot find a good motorcycle workshop to check the head, then try a high performance/racing car workshop. While they may not know desmodromics, they will identify a bent valve or damaged valve guide.
« Reply #11 on: April 06, 2019, 10:04:36 PM »
Good grief!  Corrected a bent valve?  That would mean less than .03mm run out and no less than .06mm anywhere between the valve stem and valve guide.  Please follow koko64's advice.
greenmonster
« Reply #12 on: April 07, 2019, 05:00:01 AM »
Take a pic (blur the shop name) and post it here.of the invoice.
Or tell what is says, work and parts.
M900 -97
MTS 1100s  -07
« Reply #13 on: April 07, 2019, 12:36:40 PM »
Good idea Gert waytogo
