April 26, 2024, 02:40:07 AM *
Pages: 1 [2]   Go Down
Author Topic: Won't start again different issue this time!  (Read 4076 times)
« Reply #15 on: March 27, 2019, 04:09:35 AM »
<snip>
Brown/white wire.
...and that's what happens when you go by recollection of a wiring diagram. Tongue
Brown/white it is. waytogo
Ken Masters
« Reply #16 on: March 27, 2019, 04:12:46 AM »
Thanks for the steer Duc and Howie, will test these wires and see if we can identify if this is the source of the problem
 waytogo
« Reply #17 on: April 02, 2019, 12:02:13 PM »
How did you make out?
Ken Masters
« Reply #18 on: May 27, 2020, 11:34:54 AM »
Guys, forgive me I haven't been back at the bike since today.
Had a few things happen meant I haven't ridden in a while.
Lockdown has eased here in the Uk and I'm looking to get out and ride again.
I got a pal to turn the bike on and off 4 times and tested the voltage at each of the 4 wires (positive on wire, negative on battery negative terminal) and nothing, no voltage on each occasion...
Any ideas?
Thanks
« Reply #19 on: May 27, 2020, 01:10:11 PM »
Did you check ALL of the fuses including the main fuse (not just visual)?
Ken Masters
« Reply #20 on: May 27, 2020, 11:54:20 PM »
Yes checked all the fuses including the spares visually and with multimeter, all gave an Ohms reading..
« Reply #21 on: May 28, 2020, 03:11:01 AM »
Gauges sweeping and functioning properly?  What is the immobilizer light doing?  Got power at terminal 30 (red/black at the main relay?  Power at terminal 30 at the FI relay?
Ken Masters
« Reply #22 on: June 03, 2020, 01:36:55 AM »
it looks like a case of bad soldering joints through the epoxy casing..
Here's a vid for anyone interested in this common problem:
I'm told a new pump and fittings is like £800 from ducati so I may have to go down the re soldering route.  Will have a look at ca cycleworks first..
For my peace of mind where is the main fuse located?
TIA
Ken Masters
« Reply #23 on: June 07, 2020, 08:30:24 AM »
Just to wrap this up, t'was indeed the poor soldering.
Re-soldered, bike back up and running now.
Thanks to all for your input.
 waytogo
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
« Reply #24 on: June 13, 2020, 08:38:54 AM »
 waytogo
 popcorn
-amazing!-
you just got the best of the best teaching tutorial; don't forget to bow down the DMF monster mechanic gods. And you all fixed it via internet posts!  bacon
 chug
.... all the world is yours.
Pages: 1 [2]   Go Up
