April 24, 2024, 09:50:49 PM
mangled swingarm/chain adjuster - fix?
Topic: mangled swingarm/chain adjuster - fix? (Read 2727 times)
Privateer
Re: mangled swingarm/chain adjuster - fix?
Reply #15 on:
December 31, 2018, 05:49:59 PM »
Quote from: ducpainter on December 31, 2018, 03:43:09 PM
You need to be a bit higher...
http://www.ducatimonsterforum.org/index.php?topic=50011.msg915911#msg915911
Quote from: Ddan on May 06, 2008, 12:46:27 PM
Some torque values, taken from the Haynes 2valve, '91 to '96, and LT Snyders, Vol. 1
Rear axle nut 70-76 Nm
Rear wheel axle nut 69-74 Nm
not sure which of those numbers is right, but I double checked my LT Snyder book and it says 70 nm/51.6 ftlbs.
are these not right?
I can fix it of course, but I want to make sure I'm using the right resource.
Reply #16 on:
December 31, 2018, 05:59:47 PM »
Isn't your bike newer?
I believe it uses a different size axle than the bikes the Haynes and LT's numbers are referencing, and requires more.
howie is pretty good with his info. Maybe Nick can confirm.
Privateer
Reply #17 on:
December 31, 2018, 06:10:13 PM »
Quote from: ducpainter on December 31, 2018, 05:59:47 PM
04 620
Reply #18 on:
December 31, 2018, 06:33:56 PM »
I'm pretty sure it uses a larger rear axle.
Your bike's frame is for all intents and purposes the same as a 695.
Here's a scan of a shop manual...
http://kuixihe.com/Downloads/How%20to%20repair%20and%20maintain%20Ducati%20695.pdf
It says 83
lbs/ft
Nm.
I'm assuming your bike has a 25mm rear axle.
Last Edit: January 01, 2019, 03:14:08 AM by ducpainter
Reply #19 on:
December 31, 2018, 08:21:49 PM »
Yep, 83Nm.
Reply #20 on:
January 01, 2019, 07:48:33 AM »
I've seen when the axle's ~loose, it can load up that tensioner bolt and break it.
In that case, the cap escapes completely.
And it's then even more obvious as the axle is unrestrained and slips position.
If the tensioner bolt isn't *quite* tight enough, it loosens due to the rather aggressive vibration, and then the cap self-employs, like this case.
Yes, 25mm axle is 83 N-m (63 ft-lb)
Tensioner bolts (chain adjuster screw) 8 N-m (6 ft-lb)
There's a small bolt that goes in the inner end of the tensioner bolt, keeps it from unscrewing completely from the axle slider block.
That bolt head has broken off, so it may be still sitting inside there.
Best to retrieve it so it doesn't jam the slider block at a later date.
Privateer
Reply #21 on:
January 01, 2019, 04:45:42 PM »
thank you all. updated my Desmo Times shop book.
Qomomoko
Return of the Yoga
Reply #22 on:
January 08, 2019, 12:35:06 AM »
Interesting and unfortunate story.
I was under the impression that chain "adjuster screws" were more stable/solid.
I better go play with mine and make sure all the parts are SAT, especially the retaining screw for the sliding shoe.
