9ineballer
« on: December 18, 2018, 06:06:48 PM » |
hello. so I recently purchased an 04 sr4 from a copart auction. bike is a bit rough as it came with the instrument panel missing. it did come with original keys including the red key, but im trying to figure out my options. do i send the ecu somewhere to have it upgraded /immobilizer removed? i have an aftermarket gauge id like to use with it . or should i try and find a stock instrument panel? they don't seem very available,and surely not cheap . not sure if this matters, but it does have a power commander it came with. I haven't tried to start it or anything as i assume the missing instrument panel would prevent it from happening. if anyone can let me know what to do it would be very appreciated. thanks
Online
« Reply #1 on: December 18, 2018, 06:34:36 PM » |
Your best option is to have the ecu flashed to remove the immobilizer function.
At that point the gauges are up to you, whether aftermarket or used OEM.
"Once you accept that a child on the autistic spectrum experiences the world in a completely different way than you, you will be open to understand how that perspective is even more amazing than yours." To realize the value of nine months: Ask a mother who gave birth to a stillborn. "Don't piss off old people The older we get, the less 'Life in Prison' is a deterrent.”
9ineballer
« Reply #2 on: December 19, 2018, 11:26:53 AM » |
can anyone recommend someone who does the flashing and how much it should cost? thanks
« Reply #3 on: December 19, 2018, 12:19:53 PM » |
Try our sponsor Motowheels.
Online
« Reply #4 on: December 19, 2018, 12:43:42 PM » |
You can also search ecu reflash on the search function here on the board and get other options.
9ineballer
« Reply #5 on: December 20, 2018, 03:52:30 AM » |
lol after giving the bike a good look over , i just realized the ecu is missing as well. . so i am going to assume that i need to buy an ecu from ebay then have it flashed ,yah? does anyone sell a pre-flashed (immobilizer removed ) ecu? i'll check the sponsor link and most likely go with them for the flash thanks for the responses guys !
« Reply #6 on: December 20, 2018, 04:00:01 AM » |
I would absolutely recommend talking to MotoWhels. They will know excactly what you need and not try to sell you more than you need. Other places might be good, but we KNOW that MotoWheels are Request: Use Caps while communicating. Much easier to get help if you show us respect by making your posts easier to read.
Online
« Reply #7 on: December 20, 2018, 04:00:52 AM » |
greenmonster
« Reply #8 on: December 20, 2018, 06:36:45 AM » |
Aftermarket gauge is far from plug-n-play, just sayin`. +1 on checking what Motowheels can offer.
M900 -97 MTS 1100s -07
9ineballer
« Reply #9 on: December 24, 2018, 05:53:55 AM » |
i thought i read somewhere that whoever does the flash can also remove limitations that prevent an aftermarket instrument/gauge panel from being used.
i checked with mototec and they no longer do flashes although they did make a recommendation. and i am going to assume the aftermarket system is $$$. guess i just have to find someone on ebay selling an ecu instrument panel combo. are the keys tied onto the system as well?
pepeducat
« Reply #10 on: January 10, 2019, 12:34:54 AM » |
hello, to use a counter other than the original, it is imperative to remove the immobilizer of your original ECU. I recently mounted a MotoGadget counter on an S4R, once the immobilizer removed, I even removed the key switch. you can see with this person he is extremely competent https://www.desmo4all.com/
Hunleysfriend
« Reply #11 on: February 26, 2019, 08:40:53 AM » |
Does this guy speak english? Unfortunately I don't speak french. While I could email him I'm just concerned with follow up service/questions.
pepeducat
« Reply #12 on: March 01, 2019, 12:12:54 PM » |
yes he speaks English, contact him without worries
« Reply #13 on: March 03, 2019, 01:08:17 PM » |
