April 17, 2024, 10:08:01 PM *
Author Topic: Monster s2r 800/ 749S rear shock  (Read 1017 times)
mimoracingteam
« on: December 10, 2018, 01:18:52 PM »
Hi, I have a 749S/999 Showa rear shock, on internet people change the shock and the spring. The spring rate is 75Nm, but this is for 80kg driver, my stock shock(S2R800) have a ration 100Nm but i have a problem because bike is waving in the corner. On the other side I found Ohlins technical that for a 55kg driver(thats my weight) is the spring with only a 58Nm. So I think that stock 749S with 75Nm gona be good and I hope that the bike be more stable in the corner.
« Reply #1 on: December 10, 2018, 01:51:44 PM »
You can't use spring weight recommendations for a SBK on a Monster. The linkage ratios are different. Use the recommendations for a Monster.
The valving is a different story. It may, or may not work for you.
MonsterHPD
« Reply #2 on: December 10, 2018, 09:55:42 PM »
You should also consider that te 749/999 shock has a stroke of 71 mm, whereas the Monster shock has a stroke of 66 mm. This might create a problem if you encounter a large bump; I don´t know where the rear wheel might end up on full compression with the longer stroke shock.
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
ute
I Have Titanium
« Reply #3 on: December 11, 2018, 12:56:06 PM »
I think this is the same shock i am using ...I have no issues with it at all
That being said I got it off a guy who was 200 lbs and he had it setup for his weight ...I am 220 so close enough
The only small problem is a very slight rub on the swing arm
MonsterHPD
« Reply #4 on: December 12, 2018, 01:36:33 AM »
OK, if it works, it works.
I´d still keep an eye on it, though ....
If you ever have the shock serviced, it´s easy to have the stroke adjusted acc. to the Öhlins spec to the specific application.
