April 25, 2024, 04:22:13 PM
Help with rear motor bolt removal for constands center stand
Topic: Help with rear motor bolt removal for constands center stand (Read 640 times)
LARWS2R1000
October 21, 2018, 05:41:12 PM »
Hi All - I bought one of those Constands center lifts in my attempt to learn more about the bike and do some basic service. It requires that I remove the rear engine bolt from my S2R 1000 in order to install an adapter. I tried to remove the bolt, and saw that I needed to remove the nut on the other side, which I did. However, I now can't seem to get the bolt out. It rotates with the socket with some remaining resistance but doesn't move out. Do I have to use a dowel of some sort or other means of pushing the bolt through? The bolt still has some resistance (i.e., rather than spinning freely), which makes me think that I could be doing something
exceptionally
stupid and that this is load bearing even with the other motor bolts in place. Any advice would be much appreciated!
Last Edit: October 21, 2018, 05:50:41 PM by LARWS2R1000
Re: Help with rear motor bolt removal for constands center stand
October 21, 2018, 09:09:37 PM »
The engine needs to be supported. You will probably need to tap it out with a soft drift.
LARWS2R1000
October 21, 2018, 09:46:45 PM »
Will do, thanks! I suppose I'll suppose I'll pick up some sort of small floor jack and use a brass punch. If that's a terrible idea, please let me know.
