S2R 1000 suspension adjustment: rambling thoughts and questions
Started by JonS2R, July 14, 2018, 09:30:25 AM
JonS2R
Hey guys, I'm working on getting my suspension dialed in and have some observations I want to run by you guys. I've spent a lot of time over the years reading suspension guides but I still feel like I only have a slightly better than basic understanding of this black art. My prior bikes were an SV650 and VFR800 so the Monster is definitely the nicest and most sensitive suspension I've had to adjust (excluding my mountain bike).
I weigh 155 with no gear, the shock is stock, and the forks have .9 springs and 7.5wt fork fluid from the prior owner. Although I would like to hit the track someday, my riding consists of commuting to work and joyriding on back country roads so my preference is more towards comfort rather than performance. I only have myself to help set up preload so my measurements probably aren't quite as perfect as if I had helpers but I want to at least get it in the ballpark for now and then I'll take it to a shop for help if I really need to.
I finally had time to go riding around today with a screwdriver so I could make adjustments on the road. I put zip ties around one of the fork legs and shock shaft to get an idea of how much suspension travel I was using. I set it while riding back and forth over a particular section of road that has a couple bumps and dips with sweeping corners I can comfortably take around 50-60. I chose this road because I used to commute on it and have spent a ton of time riding my prior bikes over it so I thought it would provide a good base line.
Forks:
Racetech recommends .9 springs for my weight for street riding. With the preload adjusters dialed all of the way out, I'm measuring about 23-25mm of sag, slightly less than the common street recommendation of 30mm. I've been riding for the last month or so at stock rebound/compression settings just to get a feel for the bike since it's new to me. I got a lot of road feedback through the bars that I've had to absorb with my arms, even on seemingly smoother roads. I also noticed the reflections of my headlight constantly bouncing and flickering as if the suspension isn't really absorbing road imperfections. Removing 3 clicks of compression and adding 2 clicks of rebound hugely improved comfort and feel and seemed to get it pretty close to what seemed like the sweetspot while I was riding the above mentioned road. The front end felt smoother and my arms were much more relaxed over rougher pavement. It didn't feel like the forks rebounded too much when coming to a hard stop either.
After getting home, I checked rebound by pushing down on the front end of the bike and watching the forks rise. They come back up pretty quickly and in one movement will briefly extend passed their stationary position and then settle back down. This would indicate more rebound damping is needed but when I added even 1-2 clicks more rebound while out riding, the front end felt a little less comfortable. I know you can't have ultimate comfort and damping at the same adjustment point but again I'm leaning more towards comfort in my settings.
My main question on the forks: The zip tie I put on the fork leg stopped almost 2.5" from the bottom indicating a lot of unused suspension travel. I know not all travel should be used during normal riding but shouldn't I be going through more of it? That plus the maximum sag I obtained above makes me think that maybe the .9 recommend springs are too high of a rate. Should I try .85? Or would it be better to try cutting down the spring spacer to remove even more preload than the adjusters allow? The prior owner looked to maybe have 20 pounds on me so I'm wondering if the spacers he used were short enough to get within his sag setting but too long for mine. It probably doesn't help that my weight tends to fall right in between the .85 and .9 spring rates or at least it did on my prior bikes. I also have the OEM springs if those are worth trying but then the front end would likely be too undersprung.
Shock:
The prior owner didn't have much preload dialed in when I first bought the bike. There was maybe a 1/4 inch of thread showing above the locking ring for the shock collar. The bike sagged a lot sitting on it and I could almost flat foot the bike at 5'6". The rear end would sit down a lot under acceleration and took a bit of effort to flick side to side through back to back curves. It felt ok going over bumps in the road but riding through dips caused what felt like harder suspension hits. It initially had about 50mm of sag when I measured. I've got the preload collar a little bit past the halfway point of the threaded section on the shock body which gave me about 10mm of static sag and 35-40mm of sag when sitting on it. Again, I'm doing this by myself so I'm just trying to get it within an acceptable range for now. I set the sag about a week ago and it still felt like the bike was sagging a bit too much when sitting on it compared to the front and I could still feel it sitting down a little under acceleration.
Before I went riding today, I increased preload even more by about one full revolution of the collar just to see how it would feel. This definitely helped as the bike noticeably sat higher. I'm now on the balls of my feet when stopped rather than almost being flat foot. It turned sharper and stayed flat under acceleration which threw me off at first as I thought the bike suddenly wasn't accelerating as hard although really the back end just wasn't sitting down like I had been used to. Rebound is 15 clicks out from all of the way in and it seems to be riding pretty good at this point. I'll have to try measuring preload again at this setting to see how much sag has been reduced from my prior measurement.
After riding, I checked the rear rebound by pushing down on the seat and watching how the bike responded. It doesn't seem to extend passed it's stationary position but did seem to oscillate twice before settling. Again, this would indicate more rebound should be added but doing so while riding caused me to feel bumps in the road more so than less rebound.
My main question: is it normal for someone of my weight to have the preload collar turned down so far? Racetech shows a recommend rear spring rate of 8.5 kg/mm with the stock spring being 7.4 so I know the rear is a but undersprung. It just seems weird having to turn the collar so far down when I didn't need to do it as much on my prior bikes. The zip tie shows I have about 10mm of travel left before I hit the bump stop. I know the rear linkage is progressive so it's going to take harder hits to push it further through the travel. Would it be worth swapping the shock spring out? Or should I leave it as-is if the sag is around 30mm? I ask because I've read that it's preferred to hit your sag with as little preload as necessary...
Thanks if you actually read my entire rambling post. I'd love to hear how anyone of similar weight has their suspension set up.
2007 S2R 1000
JonS2R
2007 S2R 1000
That's way too much front spring for your weight.
I'd say 0.80 for comfort, 0.85 for sporty.
There's a number of ways of getting closer to those depending on budget.
The stock rear spring is a progressive one, it can work OK for you.
Get the front sorted out first.
Dunno what's up with those RaceTech numbers.
A 10 or 10.5 would be good for the rear.
BK_856er
You're doing the right things, but don't trust that racetech calculator!
@155lbs, I think you'd definitely be better off with 0.85 or probably even 0.80 fork springs.
Best to report two sag values for both ends:  sag without rider, sag with rider.  The first requires the bike to be first fully supported by lifting the rear off the ground or the front by pivoting on the sidestand.  On the rear you'll also have a third value of free sag, which at least for a straight-rate spring can be an indicator of correct spring rate - need a bit of free sag.  Sag numbers are tricky without a helper, not only the measurement itself also but factoring for stiction.
FWIW I'm about 165lbs and use 0.85 fork springs and 625 shock spring, aftermarket suspension and straight-rate springs.
Is there a good suspension guy you could ride to?  A decent baseline is gold.  Otherwise keep notes and don't be afraid to make adjustments.  Owner's manual might also indicate the delivered settings for reference.
*edit - speeddog beat me to it!
BK
I can't see how a linear shock spring wouldn't make you happy. The very same about lighter fork springs.
BK_856er
You also mentioned ride height and the PO already changed fork springs.  Worth confirming fork tube position and ride height adjuster length so the chassis geometry is at a known starting point.
The factory fits progressive springs to accommodate a very broad range of customer weights and I suppose 2-up scenarios.  Linear springs (aka, straight-rate) will always be superior, especially when used at both ends.
I don't have an S2R1000 and its better parts, but the best thing I ever did for my M695 was to sort out the suspension.
BK
JonS2R
Quote from: BK_856er on July 14, 2018, 01:00:13 PM
The forks are about 7mm above the top of the triple measured from the top of the fork cap (not the nut). I say "about" because I did measure it when I first got the bike but forget the exact number so I'll have to check again. I just checked the manual and didn't see it specified as to how high above they should be unless I just missed it.
The rear height adjuster has no threads showing so I think that means it should be at stock height.
Can someone confirm?
2007 S2R 1000
JonS2R
Thanks for the input on spring rates. I thought that seemed too high for my weight. My VFR also came with .9 springs and the front wouldn't compress at all when I sat on it. Putting the stock springs back in made it ride great. I had .8 springs on my SV but they still almost bottomed out under hard braking so I swapped them to .85. Of course that bike is also notorious for having awful forks regardless.
I suppose I'll need to get a front stand and spring tool now.  [thumbsup]
2007 S2R 1000
BK_856er
Most of the "owner manuals" can be found with a quick google search.  It might have info on the initial suspension settings, FWIW.
The much more extensive "workshop manual" can sometimes also be found for download if you work at it, or I think the CD can be purchased from Ducati.  For example the S2R800 manual shows 25mm shock spring preload, 261mm rear height adjuster length and fork tubes flush with top triple (again, FWIW).  S2R1000 might be different, no FHE from me.
Getting the front spring rate right for your weight should be the top priority, but some of the other stuff is "free".
Good luck!
BK
DuciD03
[popcorn] !!!
okee .... this is something I know little about; but want to know more about and do; what you just wrote explains a lot about suspension setup; thanks!  [bow_down]
You got good comment back; you'll get er dialed in right.
[thumbsup]
.... all the world is yours.
JonS2R
Quote from: BK_856er on July 14, 2018, 08:08:54 PM
Good luck!
BK
Found it. Funnily enough, they specify fork height by measuring from the top of the top cap to the bottom of the lower triple clamp. 296mm +/- 1mm. I'll have to measure when I get a chance...
2007 S2R 1000
caperix
I also think at your weight a .90 spring is too much.  I have .85 springs in my bike & the preload is almost all the way out, I am about the same weight as you.  Removing space will only help is too large a spacer is installed, removing too much will just lower the front end.
Moronic
I'm about 180 without gear. In the front for my S4Rs (same basic chassis) I run a .85 on one side and a .90 on the other. This feels about right, and my riding priorities aren't far from yours.
So you should be a bit softer, but 0.9s at your weight should not be the end of the world. I have run 0.95s, and while they left me a bit short for feel the ride was still good.
Ideally the front of the bike won't respond to bumps with much vertical movement. I wonder whether something else is contributing in your case.
From what I read, the damping circuit in the S2R1000 fork is not terribly flash. I don't know what fork fluid is recommended but 7.5 weight sounds high to me. What do other people use in these?
I would not pay great attention to the results you get from bouncing a stationary bike. It is the damping when you take sharp hits at speed that will matter most, and that could be very different from the low-speed static feel.
Remember you also have the air gap to play with. You can run a soft set-up and adjust fluid levels to preserve some travel under hard braking.
It may also be that you have more fluid in the fork legs than you need (small air gap), and this is part of why you don't use all the travel.
At the rear, I use a 10.0kg/mm spring. It is great and I wouldn't want softer. For your weight, I would guess 9-9.5.
I can't believe stock is 7.4 - are you sure it is the same unit?
OTOH, if it is working then why worry? It is the practice that counts, not the theory.
Your  rear sag numbers sound pretty close to me. And you are still not bottoming the shock. You have plenty of unladen sag at 10mm, so just add preload if you want some more ride height.
Most people find these chassis feel more neutral with the ride-height adjuster rod screwed out three or four turns.
As noted, .9 fork springs are way too stiff for you. For another data point I'm 185-190 sans gear and run .975 (one .95 and one 1.0) for fast track day work.
Regarding the zip tie - that's only going to bottom out, or get close when one is braking hard, or you hit a significant bump, even with properly set up suspension. So in your case, even with softer springs swapped in, I'd not expect to see the tie at the very bottom
JonS2R
Quote from: Moronic on July 24, 2018, 05:50:06 AM
Interesting, I've never seen anyone mention running different weight springs in the forks. Any particular reason for it?
2007 S2R 1000
