April 25, 2024, 11:04:42 PM
Side stand switch remove M695
Topic: Side stand switch remove M695 (Read 1749 times)
cencalal
November 27, 2017, 05:23:09 PM »
Want to remove the side stand switch and wiring to eliminate a possible trouble spot - don't worry, I won't forget to put the stand up. Apparently i could just unplug the connector and jump the two wires (black and black/white) there, or is there a better place to do that "upstream" somewhere? I see that on some other models there's a relay that can be eliminated with a jumper wire at that location, but the 695 has only two relays, one of which has a black/white wire to it along with a couple of orange ones...
Thanks
Re: Side stand switch remove M695
November 27, 2017, 06:52:09 PM »
I have bridged the wires as a stop gap until I got a new switch. And yep I would forget to flip the stand up on my Evo. Strangely, I dont forget on my old Monster with its funky old dash warning light.
cencalal
November 28, 2017, 09:18:37 AM »
Easily done at the connector, but if I could eliminate any extra wiring or components above the connector...?
November 28, 2017, 10:13:35 AM »
You can trace them back in the loom and connect them. Remember that the stand switch will be needed for a safety cert if you sell it, so make it reversable.
cencalal
November 28, 2017, 01:53:40 PM »
I guess that was my question - where do the wires go from the connector? I can't read a schematic that I found online - is there a clear one somewhere that I could read on my laptop? Even if I could read it I probably wouldn't be able to reason this out on my own
S2R 800 '07
November 28, 2017, 02:12:59 PM »
The two wires, upstream from the connector, go into the harness. IMO it doesn't make sense to go further than the connector.
cencalal
November 28, 2017, 04:26:02 PM »
Don't want to go on and on here, but I can see where the blk and blk/wht wires go in - I'm wondering where they come out! These are too small gauge to be keeping things running - not because of the current load, but because they're so thin that they could break from vibration as happens on these bikes. If I could eliminate them and do a jump back up the circuit somewhere, so much the better.
S2R 800 '07
November 28, 2017, 05:04:13 PM »
One to the ECU and the second joins other common grounds. Both are probaly/certainly following other wires 'inside' the harness.
Wzed
November 30, 2017, 05:51:03 PM »
TPO makes a kit:
https://www.tpoparts.com/cat093/index.php?route=product/product&path=1_21&product_id=97
cencalal
December 01, 2017, 07:04:36 AM »
I'd seen this kit, but it just adds complexity. They might have worded the description differently than " This bypass kit is built to the same high standards as the OEM wiring harness."
