2016 Monster 1200 R: How Many Rear Hub Pinch Bolts?
Started by drspencer, October 25, 2017, 11:55:33 PM
drspencer
I want to adjust the chain on my 2016 Monster 1200 R.
All the videos I see show two pinch bolts on the rear hub, I only see one on my 1200 R.
Furthermore, the 2014 Monster 1200 Service Manual instructs you to tighten the pinch bolts in a 1-2-1 fashion. These instructions would indicated that there are, in fact, two pinch bolts, correct?
Thanks
Go to ducati.com -> maintenance and have a look at the spare parts catalog and the owner's manual.  [thumbsup]
drspencer
Quote from: stopintime on October 26, 2017, 12:30:29 AM
Great suggestion, but I just did that and it showed nothing.
p.124 shows the parts, but not the view I need.
Thanks
drspencer
Quote from: stopintime on October 26, 2017, 01:12:35 AM
Look again ;)
Sorry, but I'm not seeing anything on the exploded view of the rear wheel spindle.
Thanks
S21FOLGORE
You will need
T60 Torx bit
http://www.sears.com/craftsman-t60-torx-bit-socket-1-2-in-drive/p-00934491000P
https://www.napaonline.com/p/CHQS12T60
1/2" drive ratchet handle (because all T60 socket are 1/2" drive)
eccentric hub tool
Tightening torque is 40 N·m or 29.50 ft-lb.
There's only one bolt, so 1-2-1 sequence does not apply.
