April 24, 2024, 02:02:43 PM
Ducati performance ECU vs. power commander III
Topic: Ducati performance ECU vs. power commander III (Read 2772 times)
POCO LOCO
October 09, 2017, 10:00:28 AM »
I own a o6 monster 620 with Danmoto exhaust, open airbox with K&N filter, fast throttle cam , 14t front sprocket , 50 T rear sprocket. Has a power commander III with the first map installed (aftermarket exhaust stock air filter)Runs great.I have access to a DP ECU for purchase . Would I realize any gains with this ECU, or should I stick with the PCIII?
Online
Re: Ducati performance ECU vs. power commander III
October 09, 2017, 12:45:08 PM »
I would put the money towards a dyno tune.
Maybe the DP ignition map is better. Darkmonster 620 or Speeddog might know.
Note too that the PC map may be calibrated for a stock ECU (which is why it works so well) and therefore need changing for the DP ECU.
Last Edit: October 09, 2017, 04:23:38 PM by koko64
greenmonster
October 10, 2017, 06:23:46 AM »
DP ECU for better ignition map, then tune PC on dyno=best result.
M900 -97
MTS 1100s -07
POCO LOCO
October 10, 2017, 10:30:39 AM »
Quote from: greenmonster on October 10, 2017, 06:23:46 AM
DP ECU for better ignition map, then tune PC on dyno=best result.Can the DP ECU be piggy backed with a PC III ?
S2R 800 '07
October 10, 2017, 10:56:25 AM »
Yes
Online
October 10, 2017, 11:32:03 AM »
Edit. If you get the DP ECU, the PCIII will best work with a new map designed for a DP ECU. Check out the Powercommander library or finish the job to perfection on a dyno. Checking the Powercommander library, I did not see any maps designated specifically for the DP ECU.
Last Edit: October 11, 2017, 11:51:21 AM by koko64
Online
October 13, 2017, 12:13:30 PM »
Hey Poco. Let us know how you go.
xcaptainxbloodx
October 25, 2017, 11:40:12 AM »
I had a PCIII on my S2R 800, pulled it off after a year when the tune went sideways.
DP ECU or Rexxer reflash is great. sure, the PCIII will eek out a bit more power, but you arent racing so that doesn't really matter. its not enough to miss.
POCO LOCO
November 01, 2017, 11:25:36 AM »
Quote from: koko64 on October 13, 2017, 12:13:30 PM
Am currently having bike Dynoed while swapping ECUs, and fine tuning with PCIII.
Online
November 01, 2017, 12:14:31 PM »
Cool
mister704
November 10, 2017, 04:18:20 AM »
Sent my ecu to David at Rexxer and provided him with all the details of my bike and upgrades and he flashed it beautifully. No jerking, no backfiring, no extra gas smell... nothing but pure excellence.
greenmonster
November 10, 2017, 06:52:04 AM »
M900 -97
MTS 1100s -07
