April 19, 2024, 01:02:08 PM
SOLVED - M696 2009 Light Relay Error
Topic: SOLVED - M696 2009 Light Relay Error (Read 7313 times)
Re: M696 2009 Light Relay Error
Reply #15 on:
August 01, 2016, 03:59:36 AM »
To the OP...
check the bulb and connection at the H/L connector.
fingerpuk
Reply #16 on:
August 03, 2016, 10:31:13 AM »
I had the chance to test more.
Indicators and break lights are fine.
Bottom bulb comes on when pressing the flash/pass trigger.
Main headlamp is off now by default.
Top bulb comes on if I push the top slider to main beam (push it forward) AND hold down the flash/pass trigger.
Reply #17 on:
August 07, 2016, 03:09:17 AM »
Quote from: fingerpuk on August 03, 2016, 10:31:13 AM
I think you have a switch issue.
Enjoying the ride
Reply #18 on:
August 07, 2016, 05:01:02 AM »
Yup, after last report it seems that way . . .
fingerpuk
Reply #19 on:
August 17, 2016, 09:00:12 AM »
Seems that way. New bulb didn't help, I have a new relay to test but I'll look into switch gear next.
fingerpuk
Reply #20 on:
August 17, 2016, 09:08:44 AM »
Actually I'll open up the current switch and make sure it's all clean, a new switch will take until mid September to arrive now as Ducati are on holiday.
fingerpuk
Reply #21 on:
August 20, 2016, 10:21:26 AM »
Well the insides of the switch seem fine, everything is as clean as a whistle. Can't see anything wrong, sadly my multimeter got lost in the house move so can't test. I'll fit the relay tomorrow and see what that does.
Enjoying the ride
Reply #22 on:
August 20, 2016, 10:43:13 AM »
get a $5 in the meantime . . . and install the new relay . . ..
fingerpuk
Reply #23 on:
August 21, 2016, 09:43:17 AM »
So today I fixed it, the relay had popped out. Pushed it back in, problem solved.
At least I now have some spares
Enjoying the ride
Re: SOLVED - M696 2009 Light Relay Error
Reply #24 on:
August 21, 2016, 11:45:57 AM »
good to know . . .
brains_us
Reply #25 on:
December 24, 2018, 01:11:57 PM »
Quote from: fingerpuk on August 21, 2016, 09:43:17 AM
Where on the Monster is the Relay located? I am having the exact same issue and believe it is the relay as well. I pulled put the Headlight unit and the connectors are fine!
It seems I have to remove the tank to find the Relay?
Any help would be appreciated!
That is not Dead which can eternal Lie, yet under strange aeons even death may die
=> Stalla's Pop
