throttle cable routing
Started by scaudill, November 21, 2014, 04:05:25 AM
scaudill
I have a new to me 01' 750 Monster.  The throttle cables are routed thru the hole located in the ignition switch bracket.  I bought a service manual but it only shows the cable routing at the handlebars.  Anyone have a picture or knowledge of correct routing.
One other thing, how and where should the starter solenoid be located.
Thanks,
Sterling
Willthedub
Follow the cable from the starter motor and It should be connected to the star solenoid
Starter solenoid is mounted in a rubber holder under the r/h side of the battery box.
Cables go under the lateral brace at the forward lower part of the frame.
Then up through the frame on the right side of the steering head.
scaudill
Thanks,
Sure I'll be back with more questions soon.
Thanks again,  Sterling
