No dash, Died mid-ride.. Suggestions?
Started by Shawn C, November 10, 2014, 01:06:13 PM
Shawn C
The turn signals and dash just quit while cruising on my Monster 796, The battery is from when I bought it in 12'
It died a couple times when I went to start it so I threw it on a tender for the past month or so and it started immediately.. Suggestions? [bang]
Ducatamount
half fast
Skybarney
Curmudgeon
Maybe worth checking the headlight connector at the steering head for burned out terminals? That's been reported on "new" Monsters as well. Just a thought...
xcaptainxbloodx
Quote from: Ducatamount on November 10, 2014, 02:31:47 PM
Fuse?
this happened to me a couple times. if its a fuse then check the connections at reg/rec and especially at the coil for your vertical head.  they mount to the frame near the shock and can get loose then ground to the frame and short.
