May 15, 2024, 06:35:04 AM
Carb rebuild
Topic: Carb rebuild (Read 1697 times)
mxgrant185
Carb rebuild
March 23, 2013, 01:11:41 PM »
I'm having a lot of problems with my carbs on my 96 m900. Does anyone know where to buy a rebuild kit at? And what size are those carbs? I have a torn diaphragm that isn't letting my slide lift properly so I'm running off a single carb. Any info would help. Or if you have some carbs for sale, let me know :-)
Thanks and safe ridin
SpikeC
Spike in PDX
Re: Carb rebuild
March 23, 2013, 01:30:29 PM »
A dealer, maybe?
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
Ddan
Some of my best friends are whores
Re: Carb rebuild
March 23, 2013, 02:03:46 PM »
Part # 13440011A
http://www.motospecialties.com/PartOrder.asp?Store=DucatiOmaha
From a Yamaha that uses the same carb so it should fit:
http://www.partsnmore.com/parts/yamaha/tdm850/?filters
[fitting]=custom
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
mxgrant185
Re: Carb rebuild
March 23, 2013, 04:24:33 PM »
Dang! $154 for one diaphragm? What size are the stock carbs on a 900? I may just try and buy some
transplant
Re: Carb rebuild
March 24, 2013, 03:52:19 AM »
Quote from: mxgrant185 on March 23, 2013, 04:24:33 PM
That's what I said when I found a rip in one of mine.
Nothing to lose, so I repaired the rip with a bead of silicon.
Worked good as new.
Re: Carb rebuild
March 24, 2013, 03:56:04 AM »
The Yamaha diaphragm, in the second link, is under $100.
mxgrant185
Re: Carb rebuild
March 24, 2013, 12:20:12 PM »
That still seems high for what it is, but if u can afford to buy a duc you should be able to buy the parts
silas
2V
Re: Carb rebuild
March 27, 2013, 11:17:12 PM »
Hi, I have my original 900ss carbs for sale. I posted them here about a month ago after I got fcr's and am about to put them on ebay. They are off a '98 m900 w/ 26k. They have a factory pro' jet kit set for an open top airbox, square k&N & slip ons. It ran and started cold great a couple months ago when I took them off. The choke cable is broken. I just pulled the end of it from the side.
How's $150 + 20 shipping in the US? Used good condition K&N fitting orig. airbox- $15 if you get the carbs.
let me know if you're interested. thanks, silas
Ride fast, ride safe
'98 M900, '92 Yamaha TDM850
