April 26, 2024, 12:34:57 AM
Checking the valves, thoughts on clips in or out
Topic: Checking the valves, thoughts on clips in or out (Read 1691 times)
Blue
Oh no, not another
2000 M900ie Dark
January 30, 2013, 07:11:12 PM »
I am planning on checking my valves again soon on my 2000 M900ie. Looking through my notes from the last year, I noticed when I checked my valve clearances on the vertical head, the valves measured about a thou larger with the clips out than in. Strangely, it did not matter on the horizontal head as I got the same readings either way. Reading through my Ducati service manual, it does not specify one way or the other. I assume from the pictures, they have the check with the clips in. So, what to do and why?
Thanks!
Re: Checking the valves, thoughts on clips in or out
January 30, 2013, 07:42:20 PM »
I check with the clips out.
brad black
January 31, 2013, 01:43:24 AM »
out. it can make a big difference, esp if the clips are twisted.
Brad The Bike Boy
http://www.bikeboy.org
MonsterHPD
January 31, 2013, 01:43:54 AM »
Me to!
Out, that is. Forgot to quote Speeddog.
Last Edit: January 31, 2013, 01:45:25 AM by MonsterHPD
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
FrankenDuc
January 31, 2013, 03:40:44 AM »
Quote All.
Clips out, since I'm going to have to go ahead and pull and lap and refit and check and pull and lap and... so on... the shims anyway, and the clips just get in the way.
Never though about the fact the clips do bind, and if bound will mess with the measurement...
"hammer to fit, paint to match"
Blue
Oh no, not another
2000 M900ie Dark
January 31, 2013, 08:04:18 PM »
Thanks everyone for the responses. I does make it easier to leave the clips out.
I double check the manual, it does have the check with the clips in. Only when adjusting the valves do they mention removing the clips.
Quote from: brad black on January 31, 2013, 01:43:24 AM
This is what I noticed when I was trying to figure out what was causing the difference. I could see that the clips had a bit of a twist to them.
Regarding the clearances, how is the binding of clips overwhelmed when the motor is operating? Temperature?
Just thinking about openers, clips out 0.005", clips in 0.004". Fire it up and it starts at 0.004" but runs at 0.005"? I know that as the engine warms the clearance grows, but anyone have a theory?
Thanks.
Last Edit: January 31, 2013, 08:10:33 PM by Blue
January 31, 2013, 08:36:00 PM »
IMO, the forces when the engine is hot/running far overwhelm the clips.
aleq88
April 09, 2019, 01:18:05 AM »
Hi guys , can someone explain to me what is the maximum clearence that the opening and closing shims must have based on this print screen from the service manual for a monster 696? Thank you very much
flip simulator
April 09, 2019, 02:32:28 AM »
That's telling you that if you're checking and you have .003-.006" on the opener, and .0-.008 on the closer, they're OK...leave them alone.
When you adjust they want .004-.006" for openers, and 0-.002" for closers.
In practice, the closer you get to .004 opener, and 0 closer, the smoother it will run.
aleq88
April 09, 2019, 02:40:52 AM »
Ok thank you , being my first time i will try to measure the clearence first to see if my valves are in spec....however , the 696 starts and runs great, it has 22k miles on the clock...i hope i dont need to change or adjust any valve...
April 09, 2019, 03:16:38 AM »
The spec on the closer is wrong IMO.
If my valves had over .001 closer they'd get adjusted...even if I had to pay someone to do it.
aleq88
April 09, 2019, 03:32:35 AM »
spec on the closer is wrong??
got this print screen from service manual
April 09, 2019, 03:39:02 AM »
I said, IMO. Those are Ducati's 'relaxed' specs, They did that to reduce service costs. The old spec on closers was 0-.0005 IIRC.
Using them won't do any damage. Your bike will run better at the adjusting spec than the checking spec.
aleq88
April 09, 2019, 03:40:51 AM »
Ohh , okay , thank you for info
