May 13, 2024, 02:36:41 PM
How to Install Scottoiler on M796?
Topic: How to Install Scottoiler on M796? (Read 3305 times)
Wretcker
December 07, 2012, 09:32:01 AM »
Hey!
I was wondering if there where someone out there
who have Installed a Scottoiler on a M796?
And where did you install it on the bike?
Omnipotent Potentate
Personal Pretext
Re: How to Install Scottoiler on M796?
December 07, 2012, 11:16:49 AM »
Probably not - but why install? Ride in the wet a lot? Very long (500+ miles) distances before you go home? I'm curious.
Wretcker
December 07, 2012, 01:04:50 PM »
I was told there was less maintenance with the chain, when you had a scottoiler installed
Well it rains allot here, but i can`t say that i ride allot in the rain though.
no I can`t say that i ride that long every day
But there`s a good chance that i will ride 500 miles (or more) a few times next year though
December 08, 2012, 01:35:46 AM »
a tiny can of chain wax under the seat is simplier
Personal Pretext
December 10, 2012, 05:45:26 AM »
Really it's probably over kill. One usually sees them used on adventure tour bikes where dusty/gravel roads, creeks and similar poor conditions, long long rides away from civilization are more the norm.
General wisdom currently says one should check, wipe down (possibly clean if needed) and lubricate the chain at 300mi/500kms or after the chain gets wet. if you'll just be in the wet infrequently and the occasional long ride mostly on pavement then you really don't need to bother with something like a Scottoiler. High quality chain lube applied regularly should do just fine.
Not sure if it's available there, but I'm a big fan of the DuPont chain lubricant.
http://www.webbikeworld.com/t2/dupont-motorcycle-chain-lube-2012/
December 10, 2012, 05:55:55 AM »
Only the DuPont squeeze bottle of chain saver still has the waxy bits
carbmon
December 10, 2012, 09:53:13 AM »
Quote from: Wretcker on December 07, 2012, 09:32:01 AM
Hey!
..... Scottoiler .....
A nasty, slinging, mess unless you really need it for the rigorous offroad duty mentioned above
2001 M750 Monster - for quick therapy
2004 ZG/GTR1000 Concours - for sale
2012 DL650 Wee Strom - my first fuel injected / ABS bike!
1981 R100RS - long hauler emeritus (retired)
++ with thanks to Daniel Bernoulli, (almost) all my bikes have carbs ++
Personal Pretext
December 10, 2012, 10:30:55 AM »
Yeah I figured I'd leave that out - but as noted a lot of a wet lubricant (like oil) applied to the chain will get flung off the chain and onto you, the bike, the road etc etc.
December 10, 2012, 11:07:43 AM »
Quote from: carbmon on December 10, 2012, 09:53:13 AM
If it's slinging a lot, then you need to adjust it down some.
S2R 800 '07
December 10, 2012, 01:41:29 PM »
The real selling point (as explained to me by believers) is that the dirt follows the oil off the chain.
A clean chain runs smoother and lasts longer.
I almost got one, but since I stretch chains faster than they wear out it's not for me.
Adjusted right it flings (almost?) only to the front sprocket area.
Curmudgeon
December 10, 2012, 07:51:55 PM »
Quote from: ducatiz on December 10, 2012, 05:55:55 AM
The yellow can of "Chain Saver" now says "wax-based", "O-Ring safe and fling free". "For motorcycles, dirtbikes, ATV's, Go-Karts." Costs $2- more than the old stuff, ~ $6.95 from some but not all Walmarts, in the tiny motorcycle department in auto. Picked up two cans last Friday. I've been using the new yellow cans for 9 - 10 months now. Works as advertised.
Wretcker
December 11, 2012, 03:22:05 PM »
ah okey
thnx guys
