March 29, 2024, 01:56:25 AM
Fuel Injection problem maybe?
Topic: Fuel Injection problem maybe? (Read 4757 times)
Scusi
2005 Monster S2R 800 (yella)
July 17, 2012, 08:27:11 AM »
Hey guys i ride a Yellow ^^ 2005 S2R800 Ducati with Low mileage. Arrow Exhaust full system
Lately I've been having a problem where ill be riding fine on any random day and outta nowhere my bike stops running like its outta gas. (I know i have gas in it/ just filled up) Throttle doesn't work. All the lights come on and electronics are fine. I'm usually going 30-50 mph when it happens. No shuttering or excess noise. Just sounds of it slowing down. When i go to start the bike again it will try to start but the engine wont turn over. (like its out of gas) I've tried fixing it before at a mechanics place and it was fine for close to a month then the problem resurfaced. But say if i leave it in my garage with the tank up (because i'm using a battery tender, btw i just got a new battery = maybe its a bad one?!?) after it charges i flip the tank down i can start it up just fine. I stopped taking it out on fear that it will power down when i'm turning. (worst possible situation type deal
Any thoughts or info would be greatly appreciated.
Thank you
Sam
Omnipotent Potentate
Personal Pretext
Re: Fuel Injection problem maybe?
July 17, 2012, 08:43:24 AM »
When this happens, and you cycle the power do you hear the fuel pump prime (given the handle bar switch is in the 'run' state)?
July 17, 2012, 09:22:07 AM »
fuel filter?
Ddan
Some of my best friends are whores
July 17, 2012, 09:52:06 AM »
Pinched vent hose?
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Personal Pretext
July 17, 2012, 10:11:42 AM »
Quote from: Peggy on July 17, 2012, 09:52:06 AM
Pinched vent hose?
Like that one. Makes an extra bit of sense with the tank up/down too.
And it's unlikely that it's your battery. If the bike didn't crank, light up etc - then it might be. But it does those things just fine. I couldn't hurt to check on your electrical connections if you're poking around.
But a pinched vent would cause the bike to cut out from fuel starvation, and would allow the bike to start running again after some sitting time allows the vacuum in the tank to come back to normal ambient pressure....
Scusi
July 17, 2012, 11:26:04 AM »
Quote from: Slide Panda on July 17, 2012, 10:11:42 AM
That sounds logical... is this something i could order and fix on my own? for would it be better to take to a technician. I know how to follow directions but i guess it the matter of me having the tools and space. To change that hose or realign it sounds like you have to take alot of the bike apart. How much you think it would cost?
Personal Pretext
July 17, 2012, 11:38:26 AM »
$0 - Do it yourself.
The hoses run out from the bottom of the tank. There's a couple of vent hoses. Where they go depends a bit on if you've removed the emissions canister. But of the hoses from the tank, they are the smaller diamater, more flexible ones. Just lift the tank and find them. Once found, trace them and ensure the aren't kinked or pinched. When you lower the tank, keep and eye on them to ensure that they don't kink or pinch when you lower the tank back.
When you lift the tank, a couple inches of hose will move as well. It's far from unheard of that when a tank is raised and one is messing about that those hoses get pushed to a spot where they fold over on themselves or get pinched otherwise. They are quite flexible and will pinch rather than push through like a fuel hose might.
You don't need to take it to a shop or replace anything if it's just a pinched off vent hose
Ddan
July 17, 2012, 11:45:07 AM »
If it is a vent hose it's likely a freebie. Go for a ride and if/when it quits open the gas filler. If the problem is the vent you'll hear air get sucked into the tank. All you'd need to do is re-route the vent lines under the tank so they don't kink when the tank is down.
Quote from: Slide Panda on July 17, 2012, 08:43:24 AM
If you don't hear the fuel pump run when you cycle the key it's not the vent but electrical. Check the connections
Edit:
Beat me to it
1992 900 SS,
Now running
Personal Pretext
July 17, 2012, 11:48:08 AM »
Quote from: Peggy on July 17, 2012, 11:45:07 AM
Just make sure your kill switch is set to run, and the side stand is up. The pump won't prime if the system doesn't 'think' the bike is safe to start/run
Over the weekend my side stand safety interlock was playing up and treating the stand as always down - that's why I make note of the stand.
Scusi
August 07, 2012, 06:25:33 PM »
Sorry to reply soo late but it happend to me again!!! My engine cut out while i was riding. i tried to lift seat and watch hose as it went down and It worked for like 5 minutes then it cut out on me again, then would not start up again at all...
Any other suggestions?
Thanks for the input
Dirty Duc
I'd rather be an anti-
August 07, 2012, 11:12:22 PM »
In some places there are wee beasties that make nests in hoses. If it were mine, I would "crush" the hose to check for internal additions from strange insects.
Ducatis on the Salt
NFJ79
August 08, 2012, 07:44:38 AM »
My 05 S2R800 had the same problems. My bike would run fine and then it would intermittently die and not start. I thought it was a bad fuel pump. I could not hear it prime when i turn the key "on". So I took out the fuel pump assembly and tested the fuel pump on a 12v battery. Pump works just fine. The problem was faulty wiring in the fuel pump assembly. You cant just buy the wiring harness from Ducati. You have to buy a whole new fuel pump assembly which cost about $1000. When i get home I'll post up pictures on how i fixed my wiring harness.
2005 Ducati Monster S2R 800 Dark
Scusi
August 08, 2012, 12:16:15 PM »
Quote from: NFJ79 on August 08, 2012, 07:44:38 AM
oh god.....
