starter motor burned out, what else?
Started by JoeP, June 29, 2012, 04:50:42 PM
JoeP
I rode for an hour with the starter button stuck in the "on" position. Didn't notice! Now the bike won't start and I'm sure the starter motor isn't working. The solenoid and wiring are ok, but when I put 12 v to the motor, nothing happens. I ordered a new motor today, but before I open up the crank case, is there anything else that may have been damaged by leaving the starter button pressed?
Gimpy
WOW!   How'd you do that?  The only thing I can think of in addition to the starter motor is maybe the starter hit some teeth on the flywheel?  But I'm fairly certain you'd notice the starter interfering with the flywheel. It wouldn't be a subtle clunk. I would give the wiring a good look over just to make sure nothing got hot enough to melt.  I hope it is just a starter motor.  I remember seeing a cheaper than the dealer option is the inexpensive parts thread.  Good luck.
WTSDS
You will have to take off the alternator cover to remove the starter.
There may be very little damage apart from burning out the starter brushes, it's not like the motor was spinning the starter for an hour at warp speed..
Once the motor is spinning above cranking speed the starter pinion retracts.
I'd take a look at the battery as it may have been overheated from running the starter.
Once the alt cover is off  you will be able to see if there's been any damage to the flywheel ring gear teeth.
Agreed except for one thing.  Over run is taken care of by the sprag, the pinion does not retract like in a car.
I assume the starter was tested with a known good battery.  As long as those motors are running no load they are pretty tough.  Put a load on them (like turning over an engine) they get hot.
JoeP
Cool. I'll pull the cover when the new starter arrives and check for gear damage. Thanks!
mickyvee
 [thumbsdown] Many years ago, a faulty solenoid caused the starter motor to engage, whilst I was doing about 60mph, on my Jota. The starter motor was removed and examined. Thoroughly buggered and in a million bits just about summed it up. A new solid state Bosch solenoid, and a new and very expensive starter motor, got me going again.
Howley
Check out stockers for a cheap genuine Denso replacement.
Howley
You're best to contact them before you shell out for a rebuild kit. A lot of those kits fit their aftermarket starter but not the Denso.
damnitdave
I agree with "howie". These starters seem pretty tough. But I'd say it's either something simple, like brushes (which can be done with the starter on the bike, well, my bike anyway) or something pretty serious. I can be a frustrating job, but before you pull the flywheel cover, you may want to pull the end cap of the starter first to check the brushes. If they're worn down, you can replace them, but note: It can be pretty difficult getting the brush holder assembly and cap back on with the starter still on the bike. I probably wouldn't do this unless you've had starters and or electric motors apart before. If you feel like tackling it, send me a msg and I'll give you some tips that helped me with mine.
I doubt there's any damage to the flywheel, or you'd have heard it.
The stockers link is good stuff. Easy online page, fast shipping, fair prices.
My $.02. Good luck.
-DD
JoeP
I opened up the old motor and it was completely fried. Ash and broken wires everywhere. Good thing is that the new motor arrived today (thanks to everyone!) and I can't wait to get my bike running again. But before I install it and put everything back together, is there a way to bench test the new motor to see if it's working? I was going to use jumper cables to connect it to a battery. Where do I connect the leads and in what order? I see where to connect the (+) lead, but where's the ground?
You need to mount the the starter securely or get a buddy to hold it.  Positive to the lug where the positive cable would go, negative to the starter case.  Connect negative lest at the starter case.  The connection, if made at the battery last, will cause a spark that could cause the battery to explode.  This is not a very conclusive test since there is no load on the starter.
JoeP
Installed the new motor and the bike is up and running. The procedure was a lot easier than I thought. Thanks for all your collective help!
