Blown Motor
Started by Raux, May 09, 2012, 02:42:48 AM
Pedro-bot
Wow.
Where did you find this?
What's this going on and what kind of #'s does this thing put out?
I'm not a fan of turbos or sc on motos but meh, to each their own.  [drink]
Was looking at a paso site then there it was.  from a finnish tunerhouse
Pedro-bot
i fully expected to see bent valves, or a shat crankcase, maybe a piston with a hole in it... i did not expect to see that unholy beast of a motor.
Looks like it runs off the layshaft rollers?  I would like to know what they did to the layshaft, its kind of weak from the factory.
Pedro-bot
Interesting use of the triple.  ;D
you'd think with all that fancy motor work, they'd have it on a proper stand or at least the cradle.
Pedro-bot
Yeah, I can just see that thing slipping and falling, shattering in several pieces.
That would really be a "blown motor."  [laugh]
I wonder if during a tuck, this thing would try to suck your brain through your nose
teddy037.3
Quote from: Raux on May 09, 2012, 09:55:51 AM
motor -> go kart -> brain lodged into rear of skull ;D
ManaloEA
I nominate this for the Quote of the Day. [clap] [clap]
2011 M696
Pedro-bot
Brains, no.
Eyeballs, yes.   :o
Quote from: j v on May 09, 2012, 08:24:22 AM
Same here!
That is impressive though.
Wonder if it could be modded for a 2V...Hmmmmm.....
Seems like the sort of beast that would add weight and shatter cranks and cases if given half the chance  :o
Wasn't there talk of converting one "piston" into an air pump during the supermono design (as opposed to the simple balancing weight they came up with instead)?
