Got a question here: I've installed a temperature sensor (aftermarket digital gauge) on my M750 carb, located on the oil filter cap (just like the OEM sensor on the 620) and I'm reading quite low temperatures.
When outside temp is from 30F to 50F I have about 130F when cruising and 160F in the city traffic.
Funny thing, when it rains (ouside temp is about 45F in Paris) the oil temp drops below 120F when cruising. Seems the water flowing on the oil cooler is getting temps really low. If I'm stuck in traffic it comes back to normal 160F.
I have the OEM oil cooler.
The sensor is in good condition and works well. The bike runs like a charm so I don't worry too much anyway.
Do you think it's "normal" operating temperatures? I think it's a bit low and I also get the milky stuff on oil window that I cannot get rid of ....
Maybe I should try covering the oil cooler during winter.
Any idea?
Normal? Yes. Good? No. Oil likes being hotter though. I cover my cooler in the winter. It helps a little bit. Removing the filler cap after the ride will let some of the water vapor out, reducing the milky residue. Higher RPM at the same speed help too.
