Hardwiring Garmin Nuvi GPS
Started by positivecarry, July 16, 2011, 09:00:33 AM
positivecarry
Hey Guys, I bought a Garmin Nuvi 550 and this cable to hardwire it to my bike for power:
http://www.gpscity.com/gilsson-bare-wire-power-cable.html
I want the GPS to charge only when the bike's power is turned on.  Do I just splice the two ends into the power line for the rear light?  Any other issues to look out for?
DarkStaR
positivecarry
#2
Mission Accomplished...thought I'd add some notes for people searching for this in the future:
1) On the tail light, there are three connections:
Red: powered only when brakes engaged
Yellow: powered all the time when key turned on (use this one for GPS power)
Black: on the side (the red and yellow are below), this is ground
2) I looped everything on the right side, using zip-ties to put the gps power cord alongside other cable routes.
Pics below:
uglyducky
2001 996 Biposto - (sold)
DarkStaR
It would look nicer if you could run the wire between the triples and up with the handlebar wires.
positivecarry
#5
Quote from: DarkStaR on July 16, 2011, 05:17:43 PM
Agreed...wish I thought of that from the beginning.  Now fixed (and much cleaner)
DarkStaR
herm
i have the same cord, and mount. i spliced a 2 flat plug onto mine, and connect it to my battery tender connection when i am using the gps. I do have to remember to unplug it, but other than that it works great!
I'm here for a good time, but not a long time.
gr1976
What mount are you using? Where did you get it?
positivecarry
Quote from: positivecarry on July 16, 2011, 09:00:33 AM
UPDATE: This cable kept losing the power connection so I got the Garmin branded cable:
http://www.gpscity.com/garmin-power-and-data-cable-for-nuvi-5xx-zumo-220.html
Reviews for the Gilsson cable on GPSCity's website indicate that it's not a widespread issue, but does happen in some of the cables.  Just something to keep in mind.
xsephirot
Good write up! Could you reup the pics again as they seem dead? I'm also trying to exactly like what you do but electrical crap scare and confuse me which I'm hoping your pics will help.
positivecarry
Quote from: xsephirot on October 29, 2011, 05:25:42 PM
Just updated the links.  Good luck!
xsephirot
Much thanks! Did you need to solder the lines to the yellow positive line or did you just heat crimp it?
positivecarry
I soldered them.  But to be honest, I think wrapping the wires tight and wrapping electrical tape would have worked fine.
