May 08, 2024, 07:36:53 AM
building a 4 pole starter?
Topic: building a 4 pole starter? (Read 8709 times)
monsta
Perth, Australia.
June 20, 2011, 02:08:53 PM »
I still have problems starting the monsta because of the high compression, I have put on heavier wires to the starter and earth but its only marginally better.
So, now I'm thinking of making a 4 pole starter motor.
Anyone done this? Do I have to use 2 starters to make one or is there parts available for them.
I need brushes and the brush retainers and springs...
Anyone got a buggered starter they dont want?
greenmonster
Re: building a 4 pole starter?
June 20, 2011, 03:39:38 PM »
Looked at that & even bought 4pole brushes.
But, it is quite complicated to make them fit.
M900 -97
MTS 1100s -07
June 20, 2011, 03:52:18 PM »
You have probaby checked this out, but maybe there is a way of altering the starter gearing. I've heard the starter gearing on the older Monsters isn't the best ratio. Or maybe consulting an auto elec who can rebuild starters to beef up the cranking capacity. I take it that you have the headlight on/off switch too. That has made a big difference with the two high comp bikes I have owned. I bet you have probably done all these things already.
With that size bore and the same combustion chamber you must be up around at least 12.1 in compression. I bet it's retarded ignition and 98 fuel always.
monsta
Perth, Australia.
June 21, 2011, 05:51:27 AM »
thanks fella's
G.M... did you get the 4 pole brush plate, or just the brushes? was it out of a similar starter that you tried to make fit?
Koko.. nah, havn't heard about the gearing. Is there another model that has differnt ratio's that'll fit?
I've long time thought about getting a switch for the headlight, I guess that'd be an easy thing to do for now...
I've heard that BMW make a 4 pole starter that is easy to fit with a bit of machining (I'll have to do more research on that one)
I'll let ya's know if I find something..
June 21, 2011, 09:24:56 AM »
I've heard rumors that the 1100 motors have different starter gears.
Dunno if that stuff will fit your motor.
One of my customers has an M1000 with a big bore/ hi comp kit, IIRC it's a 1079cc, and it's got a light flywheel.
It's always been a bear to start.
He recently installed a Shorai LFX18 battery, said it was better.
I've just installed one in my S4, but it's not much of a test as it's not a hard starter....
Best of all, the LFX18 I've got is 1.1 kg.
It's crazy to hold in your hand, you swear they left the goods out.
greenmonster
June 21, 2011, 03:41:59 PM »
Quote
Whole plate.
Other make, some japcrap one.
Close to fit but would require lotsa fiddling/machining.
M900 -97
MTS 1100s -07
June 21, 2011, 08:29:58 PM »
will it fry if you up the voltage on the starter motor?
maybe you could run a 2nd battery. when you hit the starter switch it powers a relay and gives the starter extra juice.
id inmagine running that thing at 18 or even 24v would be killer!
Langanobob
June 22, 2011, 01:36:55 AM »
Quote from: He Man on June 21, 2011, 08:29:58 PM
Yes, you wouldn't even need the engine to start until second or third gear...
I have an old 6 Volt GMC truck that I run a 12V battery in and the 6V starter works great, no problem so far and it's been starting on 12V for years.
Bob
monsta
Perth, Australia.
June 25, 2011, 12:25:35 AM »
hmm I think I should buy this and have a play....
http://www.ebay.com.au/itm/Ducati-starter-motor-brush-kit-/230570048093?pt=UK_Motorcycle_Parts&hash=item35af0bba5d
monsta
Perth, Australia.
June 29, 2011, 04:30:11 AM »
major win today...
part of the reason I wanted to go down the track of making a 4 pole starter was because we had a bloke at work that made one for r&d type stuff.
Anyhow, he left a while ago and I thought all the bits went when that side of the business was sold.
I rang him, and he steered me to locate the above goodies!
On the right is a standard brush plate, (one brush is still in the starter housing)
the plastic looking thingy in the middle front is a 3D print of a model that was made for the 4 pole brush plate.
The others are laser cut plates for making the said plate
so.... I'm thinking I may just need the above ebay brush plate for the spare bits and cobble it together!!
still a bit of trickery to be done, but this'll make life a lot easier...
suzyj
Does my bum look big on this?
June 29, 2011, 08:07:05 PM »
Hey that's cool. How are you proposing connecting the other +ve brush up? Is there space in the back of the starter assembly wo run a (fairly thick) wire around the back, or are you going to put a second terminal on?
monsta
Perth, Australia.
June 30, 2011, 04:24:09 AM »
I reckon theres room to run a wire around the back, behind the brush retainer and spring. It'll be tight, but doable.
I'm thinking the hard bit will be fixing the brush retainer and springs, to the backing plate.
I dont think regular rivets will do?, I may have to make them and a tool to install...
Suzy... your a good person to ask...
the wire coming off the +ve has very fine strands that are wound... whats that called? any recommendations? do I just get from an auto lecky?
suzyj
July 01, 2011, 03:06:48 PM »
This is the wire coming off the brush? When you buy brushes, they usually have a connecting wire already hard soldered in. It's a bundle of very fine wires to make sure it's really flexible. An automotive electrician would be able to help.
monsta
Perth, Australia.
July 04, 2011, 06:19:25 PM »
yeah, the wire from the brush...
I'll need to extend the positive to go around to the other side of the plate.
Just ordered 2 brush plates to rob parts off, I already have a spare starter. Just need to get a bit of wire to extend the positive and then work out how I'll rivet the bits to the laser cut plate that I have...
anyone got any suggestions for the rivets?
smdub
Reply #14 on:
July 06, 2011, 01:28:59 PM »
My $0.02.
1) The wire connected to the brush is fine and flexible because the brush has to move as it wears (by the force of the little (weak) spring). The wire between the two holders can be heavy and stiff. An semi circle of copper foil would work great for clearance (wrap w/ a pc of heatshrink to prevent any shorts)
2) As for the rivets. Well, use rivets.
Look on youtube for hundreds of videos on how aircraft type rivets are driven. You need a bucking bar (or just a hunk of steel or the face of a big hammer) and a mandrel for an air chisel. Or just grind a small hollow in a center punch, use a vise top as the bucking bar, and pound away w/ a large hammer. I've never personally driven a rivet like that but it looks easy as heck.
