2001 M750 STATOR CHECK
Started by H-2 CHARLIE, June 07, 2011, 03:36:10 PM
H-2 CHARLIE
So since the bike battery goes almost dead after 25 min. the stator test would be in order ....The test  is showing one hot  yellow off the stator  kicking out a charge and two others are grounded ... no need to see if DC is comming out of the reg.ref  yet as it might work if the short wire is traced .  MAN I LOVE OLD BIKES .. :D this street fighter gets a ton of looks
H-2 CHARLIE
   OK today the stator cover came off and a burned crusty stator came off.. now there is oil that came out and thought it would be dry ?   Is this right  ?   There seemed to be some burnt oil around the stator too .                                         The pick ups around the ends were chared , more like burnded oil  i want to clean them .
Oil will come out when you remove the cover, this is normal.  I bet if you trace the three yellow wires up to the cheesy connector you will find signs of overheating, probably where the problem started.
Stators are big bucks.  Call these folk about a rebuilt:
http://www.ricksmotorsportelectrics.com/index.php
H-2 CHARLIE
  THANX HOWIE .... guess they are the only ones ... this $550 buck duc is starting to cost me  ... the dam thing runs well and sounds great  .
$550?  Runs well?  You still got a deal!
zooom
this is a great flowchart for checking electrics
and you can find decently priced stators and regulator/rectifiers here...
http://www.regulatorrectifier.com/catalog/Ducati-80
and you can menu over for the RR from the stator page.
2010 KTM 990 SM-T
H-2 CHARLIE
   Sent  both parts  off today to RICKS for a rebuild  .   I HATE HAVING MY STUFF TORN APART FOR 10 DAYS .
H-2 CHARLIE
Quote from: howie on June 07, 2011, 08:48:05 PM
Howie ...  the connector plug looked real clean and showed no heat spots but the stator was really buned and a few wires were stuck in the magnet .so since these are cooled in oil its best to have full syn oil  for the best stabil temps . hope this  new system  from RICKS works for years as this is my beater bike around town .I BELIEVE IT STARTED OUT AS A 750 SS ,AND I LOVE THE TANK ...BAD ASS
H-2 CHARLIE
  Man the 8 day wait killed me to get the ststor back. It was sitting on my porch today and it went right on no issues but the 3 wires are now red insteed of yellow . Tossed in in with 2 qts of oil and things are fine as  tomorrow i will test the volts to be sure . RICKS MOTORSPORTS  was a deal at $140 they tested my reg/rec and it showed good at no charge /$10 / my bill with testing & shipping was $140 ... cheap repair . the old stator was cooked good guess a great reason to use full syn oil for the stator wont fry as easy as dino oil .
zooom
Quote from: H-2 CHARLIE on June 21, 2011, 12:19:29 AM
I am confused...was it $10 or was it $140?
2010 KTM 990 SM-T
