Stock super bright tail light fix / project
Started by BoDiddley, December 18, 2010, 06:28:22 AM
sbrguy
so that is what you were working on new blinkers.. if they are anything like the old tail lights then it should be awesome.
Bernard, you do know that you set the bar so high when it comes to quality and pure light output with the HSI units, that anyone that buys another vizi tec product expects not only perfect quality but again superior performance?  I have confidence that you will deliver on both.
I for one can't wait to see the light output from these signals, but only 20mm for a light source? hmm wished they were bigger but hey i'll reserve judgement till after you post some pics and videos of them being used.
TO the OP, the Vizi tec HS/I units when you see them in pictures like above you say "there is no way it could be that bright in person taht is just the camera" that is until you see it in person and it brighter than the picture or any motorcycle/car brake light out there.  and as bernard said the thing has a massive aluminum heat sink along the entire back of the light with a 1 inch fan built in to the light, it looks like it was factory made if not better. its insane, if someone sells a used one on here snap it up its worth it.
mattyvas
I will wait with anticipation as I have been told a few times now that in daylight my LED indicators cannot be seen.
sbrguy
i can't wait, if bernard did what he normally does, then these indicators should be total overkill when it comes to light output. [laugh]
mattyvas
Love'em Bernard.
Any chance that they might mount on the rear of a chopped bike?
Thanks
Matty...
Jarvicious
Talk about your all time epic threadjacks.
To the OP: awesome work.  I'd rather spend an inordinate amount of time (of which I have plenty) than simply plop a ton of money down on something production.  I'm not saying there aren't already quality LED aftermarket sources, and I'm not saying the people who buy them as opposed to building their own are schmucks, but the pride and satisfaction in developing something yourself is worth it.  Well done  [thumbsup]
Back on thread-jack-track....
Bernard:
The new bikes are all 8mm mirror mount (if you care ;D )  What I'd like is a flat mounting bracket with a hole in it, to make it fit between the mirror and it's mount. Wires with connectors and long enough to plug and play. Finally I suggest one built-in LED as a conspicuous/running light (like the BikeVis bullets)
[moto]
