fuel line size/spec on carb'd monsters
Started by BlackKat, October 31, 2010, 04:33:45 AM
BlackKat
G'morning guys,
As some have you have seen on my other posts, the previous owner of my bike did many things wrong...One of my winter projects is the clean up the fuel lines a bit. The other day I wanted to measure them and discovered a couple sizes on the bike. I presume this isn't correct. I.e., 1 size going into the filter and a different coming out...
Does anyone know the correct size fuel line for a 99 750?
Cheers!
5/16 fuel line, but before you do anything try to determine why the sizes are different.  For example, some of the aftermarket fuel filters that supposedly fit have a 1/4 inch nipple.  Same with some aftermarket fuel pumps.  1/4" line will flow enough fuel for your bike.
The OEM lines were slightly smaller going into the filter so that piece is probably original.
Most people use 5/16" id for replacement.
howie beat me... ;D
5/16" fuel capable lines, here's an example of some i've used before and i like because they match the fren tubo oil cooler lines and brake lines I have on a M900:
http://www.jegs.com/i/Spectre/865/29390/10002/-1
The Mad King Pepe'
Don't know if it's the same buy on my 2001 M750 I have 5/16 up to the pump and then 1/4 to the carbs.
Mine were originally 5/16" and 1/4", I didn't like this. Now its all uniform.
I'm running 5/16 all the way, it's an OCD thing :D
Quote from: Pepe' on October 31, 2010, 08:00:37 PM
+1 on this.  I have 2 M900's in the shop now and they're both running lines as above.  The nipple out of the vacuum petcock is smaller than I feel comfortable putting a 5/16" line on (same goes for the inlet and outlet of the fuel pump and the inlet to the carbs....)
dlearl476
Quote from: Duck-Stew on November 04, 2010, 08:13:41 PM
Same with my '99 M900.  After my cracked line leaked 2-3 gallons of gas in my garage, I replaced all of it and binned the vacuum petcock.  Because the line out of the tank is larger than the one going to the carbs, I simply bought an aftermarket fuel filter with a 5/16" inlet and a 1/4" outlet.
