Kickstand and shifter dragging on track. Solutions?
Started by Alan T, September 07, 2010, 05:00:18 PM
Alan T
Hey everyone!
I ride beginner group at Summit Point in WV with only a few track days under my belt (2 at main, and my first at Shenandoah yesterday).  I'm very slow, but trying to learn the right techniques and taking my time learning in small increments. So during left turns I constantly drag the kickstand and shifter, and don't know if I should just not lean the bike any further on that side.  Yesterday during right turns, nothing would drag until eventually my knee hit for this first time (very exciting for me!  ;D ).  A coach told me my body positioning must be uneven, and I'm probably hanging off more on the right. So back to my question, is there any more room for leaning (the bike) on my left side?  The front tire is worn pretty much on the edge, but the back tire isn't quite to the edge.
More questions while I'm posting: should I be using the back brake at all on the track?  My last session I had some back end wobble slowing down from the back straight, and a lap later the back tire screeched and I slid a little bit.  Asking around, the consensus was I should use only the front brake.  I was told with the clutch engaged, rear braking can cause loss of traction.  I wasn't downshifting when I lost traction. It happened in between downshifts.  It would be a big change for me to use ft brake only, being used to using both brakes on the street.  So if I'm using only the front brake on the track, then why not for panic stops on the street?
Alan T
I should probably mention I have an 08 Monster 695 stock suspension and ride height  :)
It sounds like you may have a combination of things going on.
Stock Monster springs are way too soft for the average rider. Getting your bike sprung for your weight will be the first step.
Second you probably are not hanging off as much as you need to.
Third if you have the little nub on your side stand that can drag regardless...your shifter should not with correct springs and riding position.
I wouldn't lean any more...hard parts dragging is never good.
I don't use my rear brake at the track. I don't have the talent to not lock it up.
The Architect
What he said  ^^^^
I'll add; just buy an SS or a super bike, less hard parts dragging.  Scraping hard parts is bad.  It usually doesn't end well.
As for the rear brake, go gentle with it.  Your tire shouldn't be screeching.  Most Monster rear brakes are useless.  Your probably on the front brakes hard and are starting to lift the weight off the rear tire.  It might help to move your butt back in the seat when braking.  Get your weight back a little.  Yet don't over do it.
Quote from: Alan T on September 07, 2010, 05:01:48 PM
Dragging hardware will eventually bite you if you persist.
Like humorless said, get the bike sprung properly for you, unless you weigh ~140 or so.
How much do you weigh?
The fact that your front tire is worn nearly to the edge shows you shouldn't lean a whole lot further over.
Losing the front isn't generally recoverable for a Novice.
So it'd be worth getting it sorted out before next track day.
zooom
lets go with the obvious point from the O.P. and his 1st question....how do you keep from dragging the kickstand? take it off! Were these NESBA, TPM, or Roger Lyle days? If NESBA, I am surprised they let you past tech with it still on to be honest.
I also subscribe to what Humorless said, but in addition, add to get some 1 on 1 instruction to work on some very specific things. While you may be over a bit, your body position may need some fine tuning as well. To wear the front to the edge and not the rear seems odd to me, and something just isn't adding up.
Getting these issues fixed sooner rather than later could be to your benefit given the lack of space to safely crash without an encouter with the tire wall at the Shenandoah circuit and some points on Main as well. I would also , FWIW, look for to do some dates on the Jefferson circuit if you can, which is a much more suited circuit to your machine's capabilities.
2010 KTM 990 SM-T
duccarlos
I think there are various issues here:
1) Kickstand dragging: Take it off
2) Shifter dragging: Either increase the ride height or buy a track dedicated bike with a sportier seating position. The Monster is considered a standard, so the rearsets are lower. In theory the foot peg should hit before the shifter. Either way I would try to avoid dragging any hard part.
3)Weird tire wear: +1 of what zooom and DP (Humorless) mentioned. You might be putting too much weight forward. I find that the hardest part of proper riding technique is to position your upper body correctly.
Alan T
Well I weigh 140 lbs, and didn't think I should stiffen anything since I am so light.  But it sounds like I may be wrong.  So if I understand correctly from different posts, I should remove the kickstand but not lean the bike over anymore to avoid metal-to-asphault contact and considering the wear on the front tire.  In addition, sit further back during braking down a straight and hang off a little more.  I have a picture of me through a turn, let me post that up.
Alan T
Here we go, I think you can see the kickstand and maybe the shifter on the ground there.  A coach was telling me I should slowly try straightening out my outside arm to push my upper body further into the turn.  I'm assuming the kickstand is easy to remove and install, but I do ride the bike to work /on the street a lot.
duccarlos
I think it was Spidey that gave some of the best advise I've heard. basically he said that you should try to put your head over your wrist. If you notice in your picture you right arm is bent. Straighten it up to push your chest more to the left.
gm2
there is also a point where the monster proves what a track bike it isn't.  you may not necessarily be there, but it's out there.
getting your suspension set up specifically for you, by a professional, is the best and first thing you should do.
Like this is the racing, no?
zooom
Quote from: gm2 on September 08, 2010, 08:36:39 AM
unless you spend a lot of money modifying it to a point of almost ridiculousness....right fstrblkduc ????
2010 KTM 990 SM-T
duccarlos
Quote from: zooom on September 08, 2010, 08:42:01 AM
You would need to move the rearsets.
gm2
clip-ons, rearsets, suspension, case covers.. the list goes on
duccarlos
For that price, you might as well save up for an SS.
