S2R 1000 Loose Rear Sprocket Normal?
Started by jgrm1, March 10, 2010, 05:50:13 AM
jgrm1
I am new to this S2R 1000 and Ducati ownership, so would someone please tell me if it is normal for this bike's rear sprocket to be loose?  The bike only has 485 miles on it (405 of which I put on in the last two weeks), but if I grab it on the forward "end" of the sprocket between the upper and lower chain runs, I can move it back and forth (from left side of bike to right side) an excessive amount.  Rear sprocket play does not seem correct to me, but this is my first sssa Ducati.  I appreciate the guidance.
Best Regards,
Jeff
BMW:  2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati:  2008 S2R1000, 1998 900 Supersport Final Edition
Norton:  1974 Commando 850
Triumph:  2016 Thruxton R, 1971 T120R
yotogi
Every one that I have seen (mine included) have some play.
I have also seen this (to varying degrees) on the superbikes that were in the local Ducati dealership's shop when I went to get mine inspected and noticed that mine had a lot of play in it.
jgrm1
Thanks for the comforting response.  I am going to take a closer look this evening to see if the "play" is from the cush drive.  I cannot imagine there being a problem with this few of miles, but I suppose stranger things have happened.  I do have a rear wheel / sprocket nut removal tool in transit to me and will pull the assembly off for inspection when it arrives.
-Jeff
jgrm1
While waiting for my big nut removal tool to arrive, I can see through the rear wheel, the sprocket is simply sliding on the OD of the cush bushings.  The cush rubbers look good and the sprocket-to-cush drive nuts are properly torqued.  I would say the movement is normal.
-Jeff
battlecry
Quote from: jgrm1 on March 10, 2010, 04:56:34 PM
-Jeff
A reference to what could happen if all the things you mentioned are not the case....
http://ducatimonsterforum.org/index.php?topic=34425.0
jgrm1
I have read about the cush drive bolts backing out and machining the hub.  Not nice.  Thanks for the link.
By the way, do any of you know the proper torque for the 32mm nut that retains the front sprocket?  I am installing a 14T sprocket this weekend and my reference materials all relate to the older style two bolt retaining plate.
Thanks again,
Jeff
Quote from: jgrm1 on March 11, 2010, 03:19:22 AM
Thanks again,
Jeff
Front sprocket retaining nut  M25x1.5  186 *  GREASE B
from this post...http://ducatimonsterforum.org/index.php?topic=373.msg39052#msg39052
battlecry
My 03 has the same spec in the workshop manual, and the front sprocket shaft has the threaded hole, yet the bike did not come with a center bolt to hold the front sprocket.  It uses the plates and two small (safety-wired) bolts.  I'm sure glad I don't have to torque anything to 186.
ellingly
As the poster of the thread linked to above re: cush drives (cheers dp! Come downunder and I'll get you a  [drink] for that effort), 186 Nm isn't that bad. The key is also to grease it up - actually means the nut is on there tighter and you get a more consistent torque. Grease B is pretty much some form of moly grease.
As for the actual torquing it, I have no problem getting at least 200 Nm out of a 1/2" drive torque wrench which is 500 mm long (or, what, about 1 foot 8 inches?). The physics of it is pretty easy - 200 Nm is 400 Nm applied to the end of a half-metre (500 mm) bar. 400 Nm is pretty much 40 kg, or 88 lb, hanging off the end of that bar. That's half my mass.
Team Ghetto Racing: motorcycle racing and riding on a budget
2006 Ducati MS2R1000 road | 1973 Suzuki GT250 cafe race | 1982 Yamaha RD250LC race | 1991 Suzuki GSXR750 perpetual project | 1984 Suzuki TS250x vintage enduro | 1997 Honda CT110 postie of death | 1982 Kawasaki KH100 bucket racer
Quote from: ellingly on March 11, 2010, 04:08:08 AM
<snip>
I might as well put all the time I spend here to some good use. ;D
