April 18, 2024, 09:14:51 PM
Rear Brake Suddenly Not Working. What should I look for?
Topic: Rear Brake Suddenly Not Working. What should I look for? (Read 5493 times)
Craw
February 04, 2009, 09:12:38 AM »
Hello,
I noticed this morning that my rear brake isn't working at all. The lever feels like it moves freely and the brakes don't engage. I have an 06 Monster Dark. When fully depressed, i can still move my bike back and forth with no problem. The brake was working properly the last time I took the bike out which was about a week ago. Bike hasn't been dropped or crashed.
Could it be a bleeding issue? What are some things I should check out first to figure out what the problem is?
I'm fairly mechanically inclined, however my only experience with hydraulic disc brakes are with my mountain bike.
Thanks for your help!
wbeck257
Porkchop Sandwhiches!
Re: Rear Brake Suddenly Not Working. What should I look for?
February 04, 2009, 09:20:56 AM »
Sounds like you got an air in the lines.
Bleed them. See if that helps.
If it happens again, your master cyl. is going out.
2006 Ducati S2R1000, 1974 Honda MT125, 1974 Penton Jackpiner 175, 1972 Yamaha R5
February 04, 2009, 10:13:06 AM »
Or caliper.
ghosthound
February 04, 2009, 10:44:26 AM »
my rear pad wore out at around 5800 miles...
wbeck257
February 04, 2009, 11:29:01 AM »
If it were pads it wouldn't be sudden...
Omnipotent Potentate
Personal Pretext
February 04, 2009, 11:35:12 AM »
When in doubt, bleed it. It's the cheapest and easiest thing to check. Can't hurt to check the pads while you're mucking about back there. But a good bleeding will probably sort it.
fasterblkduc
February 04, 2009, 11:37:00 AM »
Your bike sat for a week? Just pump the lever until you have brake pressure. Then try it.
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear
, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
February 04, 2009, 04:15:16 PM »
dark 06 - how is the rear caliper mounted?
If its the one mounter below the swingarm; they are difficult to bleed mounted with an air pocket in the caliper; its better to unmount the caliper and have the bleed screw at the high point; then bleed. I the first time i discovered this was with a crashed bike and I spent a lot of time & break fluid getting no where ....
Also it is unusual for a problem like that to just show up. What work have you done to the bike? Check the break lines and calipers any leaks? and any loss of fluid?
I'll bet ya there in lies the problem-o. Happy bleeding.
.... all the world is yours.
Craw
February 05, 2009, 02:48:04 PM »
Quote from: DuciD03 on February 04, 2009, 04:15:16 PM
Brake Caliper is mounted above the swingarm I'll take a look at everything this weekend hopefully.
Thanks!
Gimpy
Not quite a
February 05, 2009, 04:33:45 PM »
This happened to me on a ride. It was a hot day, and I was on an old twisty road with lots of gravel. So I was cranking on the rear. It turns out that I blew my master cylinder. I looked into rebuilding it buts its cheaper to just replace.
Try bleeding them before you do anything. Good luck.
2001 M900 Dark
crazy bike girl
aka msincredible
February 05, 2009, 06:38:05 PM »
I had a similar issue last year and my rear brake just needed bleeding.
photo FAQ
=> Stalla's Dad
