Anyone Installed a Center Stand on a Monster?
Started by DuciD03, October 20, 2008, 04:39:45 PM
DuciD03
Hey all:
I'm intrested in Installing a Center Stand from a ST4 for a M 800 03 for winter starage purposes; has anyone installed a centerstand on a monster?
Theres a long through bolt for the rear connector looks like it should go through the header exhaust supports and the front holes should connect through the rear foot peg bolt.
In the long through bolt area there's a 2 piece metal connector for the back of the main exhaust horizontal header cloverleaf that attaches to that point along with no less than 15- bushings; bolts; connectors; spacers; washers ....  which pieces I reinstall and which ones I omit ....?  [coffee]
.... whats the best procedure and what parts to omit?
.... all the world is yours.
Howley
kenthecarp
Anderson used to make a centre (yup Canadians spell centre like this) stand for Monsters. I contacted the company in 2003 and mentioned that I didn't think it would fit on one of the newer Monsters (2003) and they agreed.
Anyways this is a work/storage stand.
http://www.andersonstands.com/index.html
DuciD03
#3
Quote from: Howley on October 20, 2008, 05:15:37 PM
To answer your question:
Yes.
... and .... the anticipation is killing me .... [popcorn]
DuciD03
Quote from: kenthecarp on October 20, 2008, 05:32:52 PM
this company used to make a centre (yup Canadians spell centre like this) stand for Monsters. I contacted the company in 2003 and mentioned that I didn't think it would fit on one of the newer Monsters (2003) and they agreed.
That  center stand in your pic looks way different from what i have; I think i have a OEM Ducati stand; matches the bike and paint ...
There's a few folks here that have the OEM Ducati centerstands.
Howley
Quote from: DuciD03 on October 20, 2008, 07:41:42 PM
Haha, you asked if anyone had installed one, and I said yes no AND NOTHING!!! ;)
You see them on ebay occasionally, and sometimes on the store here. I'm kinda tossing up whether to get one or not, cos they look so cool and retro, but i don't know if I can deal with seeing all that junk down there when it's retracted.
WTSDS
Dunno about the '03 but I put a ST2 c/s on my 2000  M900 ie. No great drama except had to heat and bend the foot lever piece outwards a coupla inches to clear the low mounted left muffler.
Teutonics
I have the OEM one on mine, and really like the added stability when parked.  Tire changes, chain maintenance, sprocket changes, etc. are much easier too, and don't require a lift stand.
Atlanta, GA - 2002 M900ie
Quote from: Howley on October 21, 2008, 02:07:38 AM
---------------------snip-------------
The ones I've seen aren't really that obtrusive.
I didn't think " :o OMFG, WHAT IS THAT?".
I didn't see it right away, looking the bike over and "Oh, it's got a centerstand.".
DuciD03
Quote from: Speeddog on October 21, 2008, 08:22:50 AM
1+;  yes it looks like it would be a clean and matching stand( unlike the photo above of the non OEM which is not so well designed) and red).   I'll post some picks once the C Stand is installed.
DuciD03
Quote from: WTSDS on October 21, 2008, 02:19:28 AM
... ok thanks for the constructive feedback;
hummm clearance issues are a problem; but nice to know that the install isn't too much of a hastle.
Did you have to omit any of the header connector pieces? or at the foot peg connection.  ( any bending sounds like a major job without the proper facilities ... I hope its a direct match.)
erkishhorde
I hear it hurts your lean clearances but I'm nowhere near being a good enough rider to reach max lean.  [roll]
WTSDS
The installation was fairly simple, but I did the fit up without the spring until I had it right. There was an alloy disc between the mount and motor that had to be discarded. Didn't have to touch anything to do with the exhaust system on mine.
I would not have bought the Monster unless I could fit a centrestand. IMHO a motorcycle without a c/s is nuthin' but a pain to live with. NO cornering clearance issues.
erkishhorde
Quote from: WTSDS on October 21, 2008, 04:18:26 PM
Sorry, didn't mean to imply that it would hamper cornering ability. You'd have to take it off if you were to track your bike but it generally won't affect a street rider. If you're really pushing the twisties it could be problematic though.
