Engine Oil sight window has milky white texture on it?
Started by paradisecity, September 25, 2008, 10:37:54 AM
paradisecity
Kind of explained the question in the title- my glass (or plastic) sight on the engine has a milky white, almost cream cheese looking texture on it (inside).  My friend has my camera so i havent snapped any photos yet.  Does anybody know what this is or could be?  And how big a deal it is?
Teutonics
Typically this type of substance is due to water in the oil.  Is this an air-cooled or water-cooled bike?
Atlanta, GA - 2002 M900ie
It's condensation (water).
One of the by-products of combustion is water vapor, and some gets past the rings and into the oil.
Usually clears up with longer/harder riding to get the oil temp up over 212 degF to boil off the water.
tangueroHondo
The motor is toasted. Don't bother trying to fix it.   Look, I'll give you$100 for the bike shipped to Washington State. [clap]
Smokescreen
seriously, not a big deal.  my previous bike got this somewhat frequently.  Never an issue.  don't only run your bike for a few minutes at a time, or it'll get worse, and change your oil when you are supposed to, and don't worry about it.
W
Catching a yellow-jacket in your shirt at seventy miles per hour can double your vocabulary.
Only a biker knows why a dog sticks his head out of a car window.
Duc Fever
if you do a search you will find at least one other thread here that discusses this issue and several on TOB.
"You have not converted a man because you have silenced him" ~ John Morely
Since it's such a reoccurring topic, I went and made a How-To thread in that section
Every fall this issue comes up.  A sticky in "Tech" may be a good idea.
WTSDS
My fix was on TOB a couple of times, so simple.
After a ride park against a wall with the 'bike leaning to the Right so the oil level is above the window.
It's a mix of oil and water, harmless except when it obscures Monster windows
Sheesh, guys were talking about flushing out their motors with solvent, replacing the window.....
Quote from: WTSDS on September 26, 2008, 06:57:06 AM
Even easier - after you've parked after a ride, while the engine's still hot - undo the filler plug and leave it open for 15 seconds.  Then cork it again.  Do that a couple times and the milks goes away.
DuciD03
Quote from: yuu on September 26, 2008, 09:20:11 AM
1+  [thumbsup] it workes for me; just dont leave the oil plug off; .... I'll let you find my old post and story ...
... I also beleive this is from water in the gas and winter condensation as mentioned above or a combination of the 2.   I think if the gas is slightly milky / cloudy it has some water contamination in it .... anyone know for sure?
.... all the world is yours.
